Results 1 to 25 of 25
    Established Member Two Rings estoniancartel's Avatar
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    OEM RS6 wastegate options
    I have a set of OEM BW RS6 turbos that have been modified by chopping up some donor ko3s. The waste gates from the ko3s were not in good shape, so I am looking for a reliable waste gate actuator option. Please let me know if anyone has any experience with the non-oem options listed below and what it would take to make them work for this application:
    TiAl Universal:
    http://tialsport.com/index.php/tial-...tes/154-mvi2-5
    Turbosmart Universal (Referenced here):
    http://www.turbosmartdirect.com/Prod...PSI-Black.html
    Mamba 2.7t Direct Fit:
    https://shop.mambatek.com/product.sc?productId=2817
    OEM BW Ko3 actuators:
    I would like to go with brand new actuators if I go this route, so not from donor ko3s. Anyone know of a retailer that sells just the actuators? Part Numbers?
    2001 S4 Avant 6MT OEM RS6 on E85
    2008 A4 Titanium Avant 6MT
    2015 Allroad APR Stage 1
    2024 RS3
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    SRM just came out with an upgraded wg option for their K24s. Don’t remember if they’re turbosmart or Tial, but I’m sure you could get a set from them. Comes with brackets and all.
    Aug 24 2014
    Newport Beach, CA
    I along with Cinesnow developed a setup to use the Turbosmart actuators on K24s (before Sean had his setup available). What we learned is you cannot use brackets designed for K24s on OEM BorgeWarner RS6 turbos, they will not fit properly.
    2024 M3 Comp xDrive
    Feb 23 2010
    Emmaus Pa
    Whoops.
    Aug 24 2014
    Newport Beach, CA
    It's not off by much, but the brackets and actuators won't quite line up on BW RS6 housings if made for K24 and vice versa. Castings are ever so slightly different.
    2024 M3 Comp xDrive
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    I've got the Mamba setup but have only stuck them on some K04 hybrids so far, not in use yet.
    I don't recommend a K03 wastegate if you plan to operate in the mid 20's boost level.
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    I’ve decided to give the mambas a try, due to the fact that a custom Frankenstein setup utilizing some of the higher end universal actuators will end up being north of $500 after being modified by apikol.
    I’ll report back here on the mambas once they are in.
    2024 RS3
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    Bumping with info for future reference. These arrived in about 5 days from Taiwan- pretty quick. The quality looks and feels pretty damn good. We replaced the stock spring with the black spring to set the crack pressure for my rs6 turbos easily with no issues. I will probably have to shave down one of the brackets a bit for mounting clearance, but otherwise all good.
    Once they are running and tuned, I’ll update again.
    2024 RS3
    Apr 07 2011
    Home of the mighty beaver
    That looks really good. Seems like a great value
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by estoniancartel View Post
    With mine the black spring cracked open at 12psi, what were you seeing?
    Aug 10 2009
    2001 S4 Avant 6 MT
    Boulder, CO
    Quote Originally Posted by FlyboyS4 View Post
    We were seeing 14
    2024 RS3
    Nov 16 2018
    Killeen texas
    FlyboyS4, how do you like the Momba wastegates? They functioning properly without needing adjustments?
    Veteran Member Three Rings protocol_droid's Avatar
    Nov 20 2009
    01.5 Nogaro Avant 6spd Sport, 14 gs350 FSPORT
    socal
    so have these alternative wg options been panning out for the oem rs6?
    Sent from my SM-G965U1 using Tapatalk
    01.5 B5 S4 Nogaro Avant 6MT Sport, OE RS6 turbos, 034 DP, 034 3.5 exhaust, ER IC's, Torque Factory Y-pipe/Heads/Built engine, 034 2.0T coil conversion, JHM Shifter, Stasis Ohlins MS Coilovers, 18Z cayenne and 034 rear brake upgrade, Sparco carbon evo and evo2 seats
    14 Lexus GS350 FSport
    22 Audi etron. Navarra blue sportback s-line.
    Sep 07 2012
    Tucson, AZ
    I tried the Mamba wg’s myself and found that they liked to stick and were inconsistent with opening and closing at spec’d psi. Would love to hear if anyone else had success with these though cause I think I am going back to standard 1 bar wg’s.
    Nov 20 2009
    socal
    yea, thats what i worry about. not sure the tial or turbosmarts are any different on the rs6. seems plenty of them on k24 but without proper alignment on the bw rs6 these are probably hit and miss perhaps?
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by protocol_droid View Post
    That's what we found in terms of making the wastegates fit on the K24s and being slightly off on RS6s, and vice versa. It comes down to the actual housing itself as the K24 is a copy of the RS6 housing but is slightly off.
    2024 M3 Comp xDrive
    Nov 20 2009
    socal
    im doing oem bw k04 wg instead. dont want any time /money headaches.
    Established Member Two Rings darren p.'s Avatar
    Nov 30 2015
    Mk2 GTI VR6 B5 S4 Avant E90 M3s
    What were people commonly doing for these when they were popular? My car came with BW RS6s, I've never had the motor out to get a good look at what WGs were used, I always assumed they were the WGs from the RS6s but now this thread has me curious. I'm re-tuning but with the old EPL tune on the car, it was hitting 26psi if that makes any difference.
    Nov 19 2014
    Portugal
    Usualy k03/4 wastegate actuators are used.
    Registered User Four Rings
    Sep 01 2013
    Sweden
    On my old RS6 setup i used OE Bosch M 16psi gates. These are NLA now as i have heard.
    K03 are bit weak, but OE K04 gates would be reliable option.
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by LightningLou View Post
    Are you sure it was the wastegates and not the flapper sticking on the exhaust housing? Did you swap gates and fix the issue?
    What turbos?
    Sep 07 2012
    Tucson, AZ
    Quote Originally Posted by Silverex View Post
    What turbos?
    Yes, I’m positive it was the gates and not the flappers. Swapped gates and issue disappeared. It would be great if Flyboy or anyone else who ran these would chime in as well, cause maybe it was just me. I even took them apart and couldn’t really see any defects, but the sticking still occurred at random.
    Nov 20 2009
    socal
    lou, what gates did u swap to and solve your sticking issue?
    Sep 07 2012
    Tucson, AZ
    Just the traditional sealed diaphragm wg’s. Think the ones I’m using are of the 1 bar variety
    Nov 20 2009
    socal
    ok thanks
