Results 1 to 13 of 13
    Mar 05 2013
    18 TTRS, 09 Audi TTS, S5 Stage2, TT Mk1 Roadster
    Lakeland, FL
    Hitting the Track to Test DAP new TTRS/RS3 Brake Pads and Girodisc Rotors
    Taking my too expensive and not track capable ceramic front brake and rotors off and my street pads and rotors off for G-LOC front R12 rear R10 and GiroDisk all the way around for an all day Wednesday track evaluation. While I was at it I went to 034 Motorsports for their DogBone insert and rear subframe insert to tighten the rear. My Car already has a custom stage 1 IE tune. I also will install my custom made scoops and lower control arm deflectors (deflectors are off my Gen2 TTS, from TT Stuff). I also made some custom .040 Titanium Shims to try and save the dust boots.
    For those of you wondering. YUP 8.5 lbs added up front and I lost 1.5 lbs back aft!
    IE Twin Scroll EFR 6758 Stage 3+, AquaMist WMI, Wagner Intercooler, 42DD 3" Cat_Back, APR HPFP, UM DSG stage 3, Race Hadlex, 034 Catch Can, MSS springs, Nuespeed ARB front rear, 034 Rear ARB links, 034 Rear Trailing arm bushings, 034 dogbone and mtrmts, Tyrosports deadbolt, OZ Racing Wheels, Michelin PS3, P3, Schroth Quick Fit Pro harness, Stoptech Rotors and SS Brakelines, Tyrolsport Caliper Guides and Hawk Racing pads.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    So you replaced the Oem brakes to save money? do you just want to have a a second of brakes for the track? or are you just going to leave the giro disc on permanently? . I thought the carbon ceramics were more capable for the track, I mean, I know they are more expensive but for a person that has $80000 laying around to buy a TT-RS that should be a problem.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Mar 10 2017
    TX/USA
    Quote Originally Posted by S3DUDE View Post
    Almost everyone who tracks cars swaps ceramics out. You burn through them quickly and they cost a fortune for no added benefit in performance. The weight difference isn't worth it. Go check rennlist, the Porsche folks do it too, this isn't about being cheap.
    Aug 29 2017
    Tucson, AZ
    Quote Originally Posted by ormandj View Post
    I knew that they were super expensive to replace but what is all the fuss about the ceramic brakes then? I had STOPTECH st-40 on my new s3 and I have Brembo GT 6 pistons 380mm two pieces rotors on my A6, I mean, I know the market prices but it seems like pointless to even get the ceramic brakes from factory if you ever plan to do road courses don't you think?.
    On a different note those gyro disc look freaking nice.
    at 3100ft elevation
    Mar 05 2013
    Lakeland, FL
    Ceramics are great on the street. No dust, no brake job for 100K. I too thought they would be great for the occasional track day.
    Good Read on differences between Carbon Ceramics and Carbon Carbon Ceramics.
    There is a lot of confusion out there when people hear "carbon brakes". In racing, carbon-carbon (C-C) is used wherever the rules allow it. For high-performance road vehicles, carbon-ceramic matrix (CCM) is the rotor of choice. Carbon-carbon brake systems consume both the rotor and the pads, where CCM brakes are designed to consume only the pad.
    There are a few different ways to make CCM rotors. The ones on the Scuderia you mention are made from three pieces, a chopper-gun-like core and two face plies -- and only those face plies are siliconized into carbon-ceramic. The core remains C-C. So far, this style of construction is more delicate and less user-friendly than a full 3D CCM, like those on the STILLEN GT-R upgrade. The 3D version takes longer to make and requires more energy, so they end up being more expensive.
    The enemy of CCM brakes is not wear -- they are very, very hard (approaching diamond hard!). The real issue is oxidation. As long as rotor temps are kept below 750°C / 1400°F, they could possibly last the life of the car or even longer. If run for extended periods of time over that temperature, oxidation will start to convert the carbon molecules to carbon dioxide, which just floats away. So it pays to keep track of rotor temps, which is why we apply paint temps at STILLEN before we assemble them to the hats. Cooling kits are a great idea for track use. Keep in mind that the pads will also run hotter as the rotor has less mass to absorb braking energy than iron discs, so the CCM discs will heat up everything around them a bit more.
    Now here is another interesting point: If you were to oxidize those Scuderia CCM rotors (or the ones on any Ferrari, Lamborghini, Porsche, Aston Martin, Audi, ZR-1 Corvette, etc.) you get to throw them away after they lose a prescribed amount of mass. With the Stillen GT-R system, surface oxidation can be ground off to where the rotor looks like new again. This can only be done with a full 3D CCM rotor, not the 3-piece laminated type like on the other cars mentioned above as you would grind right through the thin face plies!
    If we chose to go with the 3-ply route instead of 3D, we could probably lower the price a couple grand -- and then have to deal with the occasional dissatisfied customer who would have to replace a front pair when they were excessively oxidized or if damaged by putting wheels back on the car. In the service manual for the ZR-1, the service tech is required to place a foam ring around the rotor before removing a wheel. If not, the dealership gets to pay for a new rotor if he chips it. While I certainly don't recommend pounding a wheel against the STILLEN/AP Racing CCM rotors, we are much less concerned about careful, routine service creating such a problem.
    Even though carbon-carbon has been around since the 70's (I started working with C-C in 1990), the more recent availability of CCM to the general public will continue to cause confusion until we get further down the road. They are not the same as iron in any capacity other than they are roughly the same shape. We can't expect that after 100 years of iron drums and discs that CCM technology will be completely understood by the masses for quite some time. Then add the fact that they are still changing as companies continue to look for ways to reduce the manufacturing costs.
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Same as anything else; over hyped by people that don't research and have more money than sense. Just like the drilled rotor fad we are still suffering with.
    Exactly why I was so annoyed that they locked good options like OLED tails and static suspension into a overpriced package with useless stuff like ceramic fronts and CF engine cover.
    Agree, these are some nice looking brakes, looking forward to the results.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Established Member Two Rings Screaming Eagle's Avatar
    Jan 27 2015
    Metro Orlando, Fl.
    I'm tracking my TTRS this weekend at Sebring. Hope I fixed my brake problems with
    Ferodo DS1.11 racing brake pads and AP J hook rotors. The cooling fins are over twice
    as wide as my stock rotors, the guy at Essex Parts said these rotors should make a big
    difference keeping them cooler. Will find out this Sat. & Sun.
    2018 TTRS Glacier White, Tech Package, B&O, Black Optic, RS Design Interior, Red Brake Calipiers, Carbon Fiber Inlays, RS Sport Exhaust.
    2016 S7 Ibis White Traded
    Jan 27 2015
    Metro Orlando, Fl.
    The new set up worked great. Stopped good and no heating problems at all. He was
    right the J hook disc make a huge difference.
    Mar 05 2013
    Lakeland, FL
    I had Zero fade or heat issues after 10 laps sessions with over 100 laps, followed by 3 days of mountain runs. They do squeal like crazy coming to a stop. I am most impressed with how good the cold stopping is. I would use these daily and have no issues.
    Veteran Member Three Rings dgszweda's Avatar
    Nov 07 2011
    Jacksonville, FL
    Why would you purchase the brakes with the car, just to take them off. That was the primary cost of the whole Dynamic package. If you were going to track the car, why did you buy the Dynamica package, just to take it off and replace it?
    2018 Daytona Gray TTRS - Tech - Red Stitching - Black Optics - Sport Exhaust
    2014 Daytona Gray RS5 - MMI - Black Nappa - 20" rims - B&O - [SOLD]
    2008 Sprint Blue RS4 - [SOLD]
    2012 Monsoon Gray S4 - DSG - Sports Differential - B&O - Advance Key - MMI Navigation - Black Nappa
    My 2012 S4 Build Thread - [SOLD]
    Mar 05 2013
    Lakeland, FL
    Because I'm Rich and wanted OLED tailights, Direct read TPMS and Non Magnetic shocks!
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Quote Originally Posted by Brd.Prey View Post
    LMAO
    I was going to make a smartass comment saying that.
    I would have gotten the Dynamic and pulled off the ceramics just to get the OLEDs and fixed suspension too if I had the money to burn. Actually, I'd sell the ceramics to someone that wanted them and offset the cost. lol
    Mar 05 2013
    Lakeland, FL
