Results 1 to 13 of 13
    Nov 28 2009
    Winchester,va,east coast
    2004 A4 rear windows not working from master switch
    Ok so I just recently purchased an 04 B6 pretty much fully loaded. The front driver window one touch does not work but does roll up and down, the passenger front window will roll up and down but the one touch is hit or miss, neither rear window will work from the master switch. If I reach back I can work the switch and they work just fine. I'm leaning towards the master window switch as being faulty, has anyone else ran across this?
    Jul 10 2015
    Colorado
    Yes. It sounds like the child lock for the rears is broken. Replace the master switch assembly.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Just curious, but do you have issues with anything else on the driver door besides the window switches? Only other option would be broken wires in the door jam, but I'd think that would be unlikely if only the window switches were affected.
    Sent from my Pixel 2 XL
    Veteran Member Four Rings jpulll's Avatar
    Jun 19 2014
    Ohio
    I had a similar issue. The one touch was hit or miss on the passenger side. I ended up just replacing the master switch because it was peeling real bad...but it cured the issue! Give it a shot, I grabbed mine off eBay.
    Sent from my iPhone
    2003 A4 1.8T 5-spd Frankenturbo'd.
    Nov 28 2009
    Quote Originally Posted by imnuts View Post
    Just the windows. Mirrors work fine, lights come on when opening the door. Locks work
    Apr 07 2011
    Quote Originally Posted by kwilson View Post
    Agree. Just had to replace the master switch on mine for the same reason. Rear windows now work with no issue from the master switch.
    Rest in Peace Four Rings EURO_DOLL's Avatar
    Jul 22 2011
    Long Island, NY
    Silly question - have you tried resetting the auto up/ down function from each window? (Rolling down, holding for a few seconds/ rolling up and holding for a few seconds?).
    BOOBS& BOOST
    Current: Bagged 04 B6 A4 1.8T | Bagged 2017 MK7 Golf R
    Past: 03 B6 A4 3.0 Quattro
    Bagged 02 B6 A4 1.8T FWD
    14 MK6 Jetta
    Static 94 Corrado SLC
    15 Golf TDI
    Instagram: @boobsandboost
    Nov 28 2009
    Quote Originally Posted by EURO_DOLL View Post
    I have tired it but it didn't work, and the rear windows won't respond to the driver window switch
    Jul 22 2011
    Long Island, NY
    Quote Originally Posted by mongold88 View Post
    That happens frequently when the auto up/ down needs to be reset from each of the window switches individually. Front LT, Front RT, Rear LT, Rear RT. But since that’s not it, definitely agree with everyone above.
    Master switch replacement.
    Good luck dude!
    BOOBS& BOOST
    14 MK6 Jetta
    15 Golf TDI
    Jul 14 2009
    Pasadena
    Good luck dude!
    well, well, well look who is back
    IG: @matthewee
    Aug 12 2009
    Dirty Jerz
    Good luck dude!
    You can reset the full open/close with any window switch, it doesn't have to be each individual door. I've only ever reset it from the driver's door switch.
    Jul 22 2011
    Long Island, NY
    Quote Originally Posted by itsmatt33 View Post
    Soon!
    Typically, yes.
    But I’ve had issues with customer’s Audi’s where I’ve had to reset them individually because it wasn’t adapting from the master switch, especially if you can’t actually roll the rear windows down from that switch itself to do the reset.
    BOOBS& BOOST
    14 MK6 Jetta
    15 Golf TDI
    Nov 28 2009
    just an update, I bought a new window switch and installed it windows are now working as designed and Im so happy
