Originally Posted by
mysticjocephus
I have an '02 A4 Quattro 3.0 and for the life of me, I can't seem to figure out which headlight bulbs I'm supposed to have, and/or how to replace them. I have only had the car for a few months and I drive with my fog lights on constantly because the stock low-beam lights don't seem to do much.
If your 3.0 has Xenons, and my '05 3.0 does, I can say that changing the bulbs is actually pretty easy once you've done it. My Xenon lights were very dim when I got the car, and when I removed the "bulbs" I could see why; the glass arc chamber was totally opaque white. I ordered OE type Sylvania D1S units from autohausaz, and I would skip the popular blue tints. Here's how I went about changing them:
Attach a T30 Torx bit to an extension; 1/4" drive is best due to tight clearances. Remove the two upper screws at each headlight, then locate and loosen by a few turns, two lower screws. On the driver's side, you may find it easier to remove the two screws (10mm hex heads) which hold the power steering reservoir, so it can be shoved over a little to access one of the lower screws. On the passenger side, remove the intake duct to access those lower screws.
Pull the headlight assemblies out the front- but you'll need to unlatch each headlight's electrical connector. Move them to a work table.
On the rear of the headlights is a plastic door with a wire clip retainer. There were also a couple of small Torx screws to remove. Open the doors and you will see the back of your bulb, a shiny rectangular metal box with a connector. The small connector pushes off, then grasp the metal box and pull straight out from the retaining spring fingers. Install the new ones carefully, pressing fully into the spring finger retainer. Plug the connector on, close the door, and reinstall the headlight assembly. Make sure the headlight assemblies are up against the two adjusting screws as you tighten the four housing retaining screws, to keep the aim correct.
While mine was out, I went some extra steps and poured a cup or so of industrial-strength Isopropyl alcohol into the headlight with the lens facing down, shook it around to clean the inside of the lens and the reflectors. After that, I used a polishing kit on the outside of the lens. Nice, bright lights now!
