Quote from: Sean@APR
A normal shift de-rates the engine by telling the ECU to pull timing. It does this to prevent free-revving and to lower the torque at the clutch to make shifting easier. It has the engine de-rate while it's opening the first clutch. The engine free-wheels for 50ms or so while the second one is being closed and then the TCU tells the engine to bring back the power.
When in this mode, the TCU keeps the beans on the entire time. There is no de-rate at all. It controls the engine RPM by having both clutches engaged in the linear (slip) region together while it transitions between the two. The upshot of this is that there is no de-rate, the engine is making full power the entire time and is transmitting it to the ground even during the shift. The downside is that it's extremely delicate. If the transition time is too fast, the clutches won't slip enough, will be working against each other and will rip themselves out of the transmission. On the other side, if the transition time is too slow, the engine will free rev, hit the limiter and de-rate via the rev limiter. It comes back as soon as the clutch closes a bit more and pulls it off the redline, but it still spent some time in de-rate.
