Results 1 to 16 of 16
Thread: LED fog lights
    Established Member Two Rings Big_Reyn's Avatar
    Aug 15 2014
    2002 GMC Sierra, 2005 Toyota Camry, 2018 Infiniti Q50
    DFW
    LED fog lights
    I want to put LED fog light bulbs in my 2011 a6. What bulbs are being used. Looking for a good quality bulb. Thanks in advance for the responses.
    Sent from my Pixel 2 XL using Tapatalk
    Senior Member Three Rings Kriskrk's Avatar
    Oct 19 2017
    London
    LED fog lights
    I’ve installed ones with heatsink, no fan.
    Close to intercooler but fitted no problem.
    Bit blue-ish tint but wicked look
    Audi A6 C6 4F 170 Sline 2.0 Avant LeMans in Grey
    Stage 1 remap with EGR off and DPF gutted, partly dechromed with blacked out RS honeycomb grille, standard 19" LeMans RS4 type wheels (deu to change), full led interior, upgraded Osram CBI bulbs, fog's power led's with heat sinks.
    More to come
    Senior Member Two Rings niedzial1983's Avatar
    Jun 05 2016
    surrey, uk
    £6 ebay blue bulb :)
    Sent from my SM-G950F using Tapatalk
    Aug 15 2014
    DFW
    Quote Originally Posted by niedzial1983 View Post
    That looks good. Do you remember which building you have?
    Jun 05 2016
    surrey, uk
    Mine are h7 but your facelifted will be h11
    Jun 05 2016
    surrey, uk
    This should work for you
    Aug 15 2014
    DFW
    Thanks
    Aug 15 2014
    DFW
    I purchased a set of the canbus decoders and used some h8/h11 led bulbs I already had. The light was bright white like I hoped for but unfortunately my car still reads that the bulbs are out. Anyone have ideas why I am still getting the code with the canbus decoder.
    Jun 05 2016
    surrey, uk
    Quote Originally Posted by Big_Reyn View Post
    A6 c6 hates led :)
    Oct 19 2017
    London
    I confirm that.
    Although, I’ve made some improvements and relay/load resistor loom but still get occasional bulb dash errors
    More to come
    Stage 2 Banner Advertiser Four Rings deAutoLED.com's Avatar
    Feb 13 2015
    US
    Clean white
    No errors
    Plug & Play
    No glare
    NO bulky wiring or resistors
    Very bright on sides and down the road - perfect for cornering and darker roads
    You can also rotate these 360 degrees to achieve the best beam angle for your reflector housing which is important as we have seen different reflector housings require the LEDs to aim in different areas for the best beam angle possible without any glare and most light on the road:
    http://deautokey.com/product/led-hea...ast-1800-lumen
    deAutoLED.com
    Facebook.com/deAutoKey
    Instagram.com/deAutoLED
    Lifetime Warranty & Support | Free Shipping within the US | LEDs Tested to work and look good in your car | Customer Service is our #1 Priority - We care what you install in your car!
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    Quote Originally Posted by deAutoLED.com View Post
    Clean white
    No errors
    Plug & Play
    No glare
    Have any in yellow?
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    Clean white
    No errors
    Plug & Play
    No glare
    Have these been tested on the C6 A6 platform?
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    These have housings AND LED bulb included if I'm not mistaken. I bought a set and will report back once I get them. ePacket, so it should be a couple weeks.
    https://www.aliexpress.com/item/Car-...837176991.html
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Dec 01 2007
    Orange County, NY 10918
    Ijdmtoy h11 YELLOW led bulbs with ijdmtoy 50w resistors. Work great
    Sent from my SM-G930V using Tapatalk
    C6A6 3.0t Avant
    @avantneil
    @avantoberfest
    @skiguardusa www.skigaurd.com
    Sep 28 2014
    2007 Suburban
    looks like I need to buy the harness.
    Jon
