Results 1 to 32 of 32
    Dec 10 2017
    California
    Used S4 - Which year is best 2014, 2015, or 2016?? Things to consider?
    Just starting our search for a late model, low mileage S4; and wondering what year 2014, 2015, or 2016 stands out as the best. Also, any recommendations on things to consider or check out.
    And, living in California, I'm considering APR Stage 1 tuning, and would like input regarding the SMOG testing ramifications. I have read random sources say that it passes with the new programming in place, while others recommend reflashing to stock ecu and put some miles on the car before testing. But, I question the qualifications of those sources; so, if anyone here with first person knowledge can confirm the implications of APR Stage 1 tuning.
    Very excited about finding the right S4, and looking forward to input from members here.
    Thanks.
    Steve
    Feb 28 2017
    Orange County, CA
    What’s wrong with a 2013? Virtually the same car and you can find some great deals as well.
    2014 Audi S4 Prestige, Panda Interior w/ Sports Differential
    Junior Member Two Rings mpm's Avatar
    Sep 06 2017
    2014 Q7 TDI Prestige
    Hershey, PA
    As someone who just did the exact same search for about six months, I can tell you from an equipment and options perspective the three years are identical vehicles. There are minor changes in how the options are organized, but not in the actual options themselves. There are also some changes to the wheel styles.
    First, the best thing to do is get a copy online of each years A4/S4 brochure so you can see how the options were arranged. This will help when trying to narrow your search across different years.
    Second, when comparing different cars for sale, skip reading seller provided info (as it usually contains mistakes) and pull your own original window sticker. This will allow you to quickly know exactly what the vehicle is equipped with and compare to other prospects. Here is a great tool that I used that others have also posted about on the forum:
    http://www.wikilender.com/ultimate-w...-decoder-tool/
    I ended up with a 2014 prestige fully loaded, as I only wanted a manual and they are few and far between. I shipped it from California to Pennsylvania. You are lucky being out west, as CA had the most offerings of any state during my search.
    Good luck!
    2014 S4 6MT | Prestige | Brilliant Black | Black Optic | Rear Sport Diff | Driver Assist | Adaptive Dampening Suspension
    2014 Q7 TDI | Prestige | Daytona Gray | Black Optic | Offroad Style Plus | B&O | Adaptive Air Suspension | Tech | Towing | Cold Weather
    Departed: 2006 A4 6MT | 2.0T Quattro | 207k miles and counting
    Sep 06 2017
    Hershey, PA
    Regarding the 2013, I don’t believe that MY MMI supports Bluetooth audio streaming if that matters to you. It only supports phone calls.
    May 01 2012
    Quote Originally Posted by mpm View Post
    It sure does.. at least it does on my ‘13
    Jul 07 2017
    usa
    It definitely does support Bluetooth audio streaming
    Sep 06 2017
    Hershey, PA
    Good to know. I knew it became available in 13 or 14. Just wanted to throw it out there in case, as it is in an obscure MY change not obvious in any literature. Appreciate the feedback from 13 owners.
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    I've heard the early MY13's still has the ver 1.5 DSG (out of Ver 1, 1.5, 2). Not sure if you can vagcom scan which model DSG is in them. According to the poll, Ver 1 DSG has the mechatronic issue, not sure if the 1.5's have the same issues or not.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Feb 28 2017
    Orange County, CA
    Just purchased my 2013 S4 prestige, 22,000 miles for a very good price.
    My friend bought a 2015 s4 and I can tell you with 100% certainty that the differences are marginal if any at all. I can confirm that I have Bluetooth audio for music, anything 2013-2017 is a b8.5 and are relatively all the same. So if you find a good deal ‘13 I’d go for it.
    Established Member Two Rings Estoril4's Avatar
    Aug 20 2017
    North Carolina
    Simply put go with the newest/lowest mileage you can if it's a decent deal. 15s and 16s you'll still have some warranty to iron out any gremlins unless that doesn't matter to you, I'd probably try and find one with ~ a year left
    Sent from my SM-G955U using Audizine mobile app
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by Estoril4 View Post
    +1, Did exactly this.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 15 2012
    MA
    I owned a 2013 and now a 2015. Differences are minimal between the years. Keep in mind that some 2013's had steering issues being the first release with electric-assist steering. There was/is a large thread in here documenting people's issues. I also had the notch feeling with mine and it was never 100% after the TSB was applied. This also made the adjustability from the MMI less-noticeable when comparing comfort, dynamic, etc. I don't notice any steering issues on my 2015.
    2015 S4 - Premium + | Sepang Blue | DSG | MMI Nav | Sports Diff | B&O sound | Carbon Atlas trim | All weather mats and trunk liner | Technology Package | Black Optic package
    Mods: Winter - OEM 19-inch Titanium V-spoke-design with Blizzak LM32 Snow tires | Expel Ultimate PPF full frontal wrap
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    It doesn't matter. The differences are so insignificant. Find the newest model year with the lowest mileage in a color combo you like with the options you must have, at a price you can afford. The model year is least important .The driving experience with all b8/8.5 s4s is the same. Forget about a CPO or extended warranty if you plan on tuning the car. The first time you take it in to an Audi dealer for service, they will connect it to their computer which is programmed to ferret out any tunes. Your car will be designated TD1 and engine and drive train warranty voided. That pertains to aftermarket warranties as well. Dealer has no way to circumvent this.
    Dec 10 2017
    California
    Wow, first, I want to thank everyone for taking the time to help with my search. Such outpouring is comforting going forward.
    I will add 2013's to my list,
    I appreciate the input re CPO's, which pretty much confirms my thoughts about what seems to be simply an extended warranty - philosophically, something I routinely stay away from, because seems like quite a good add-on for the dealer, ergo bad investment for the buyer.
    Thx again to all.
    Steve
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by sgomes View Post
    Thx again to all.
    Steve
    Cpo is a great add on for the buyer as long as you are not tuning the car. But IMHO, not a deal breaker either way. Plus these cars have been remarkably reliable even with higher mileage,
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Year doesn't matter all that matters is if it has a 3rd pedal.
    Sport diff is nice to have also.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Established Member Two Rings RCFC89's Avatar
    Jan 28 2017
    Quote Originally Posted by Dr GP View Post
    Chipwerke piggyback doesn't show up. Doesn't have to be CPO or extended if you find a 15/16 model year. My 2015 still has 23 month's left on the original warranty.
    2015 Nogaro Blue S4 (Prestige/Black Optics/Audi Exclusive Interior)
    Feb 08 2014
    2013 :-)
    Mine has BT audio. Just turned 40k mi and no issues whatsoever.
    2013 S4 Phantom Black - Aluminum Optic | DSG - Sport diff | EPL Stage 2 single pulley - EPL DSG tune - ST-X Coilovers - 034 rear ARB - CR-15 upper strut brace - Eurocode transmission and differential inserts - slotted rotors - Stoptech sport pads - Motul lube - Firestone Firehawk Indy 500s
    1965 Mustang Convertible Rangoon Red | AT | All original - rally pack - styled wheels
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by RCFC89 View Post
    Correct. But OP stated that he was considering a APR stage 1 tune.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Quote Originally Posted by RacrX View Post
    2013 :-)
    Same.
    Sep 22 2013
    Be careful with 2016s, the ECUs changed and some people have issues with tunes that tuners are not ready to address due to the small demand.
    Active Member Two Rings hubner33's Avatar
    Jun 03 2017
    Pickering/ontario
    Dont the 16 also have port injectors that help with the carbon buildup ussues
    Dec 01 2015
    Do any manual S4s come with CarPlay/Android Auto?
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Quote Originally Posted by fafaforza View Post
    No.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by LINDW4LL View Post
    No.
    Dsgs don't have it either
    May 03 2017
    Oakland, CA
    Quote Originally Posted by Dardan View Post
    First I've heard of this, if thats the case I may have to reconsider tuning mines in the future. By chance is there a link you can send me so I can read up on it?
    Dec 14 2015
    Orange County, CA
    Quote Originally Posted by BoringGuy View Post
    I've heard of it before, but luckily Chris at EPL confirmed my 2016 was good to go.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Deactivated Four Rings
    Jun 23 2011
    2016s are no different in North America. I think in 2016 the UK and other Euro countries got the newer Simos16 ECU and engine with the port and TFSI injection as well as the 4 bolt pulley. But in North American all the way up to 2017 are fine with the S4/S5s.
    Sep 14 2017
    Northeast
    Quote Originally Posted by Chris@EPL View Post
    Good to have that clarified. I was under the impression it was USDM as well.
    2018 Nardo RS3 - Milltek Mids, CTS Intake, CC ECU+TCU, RSe10s - 10.90 @ 129.6mph, full weight
    2016 Mustang GT - Procharged - E85 - 772whp
    2003 Mustang Cobra - Whipple - 640whp
    SOLD
    2012 S4, MK7 GTI, 15 STI, 2013 Boss 302, 03 Cobra, 09 WRX, 04 WRX, etc
    Jun 23 2011
    Only the 2016-17 A6/A7s got the new 3.0T with port injection/Simos16/4 bolt SC pulley.
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Will their LPFP pump work for our S4/5 since its direct/port and probably higher capacity? Part #?
    2014 is best
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Jun 23 2011
    Quote Originally Posted by RWD2quattro View Post
    No idea.
