Results 1 to 19 of 19
    Established Member Two Rings nks979's Avatar
    Mar 10 2017
    Arizona
    MMI reboot while driving
    So, 3 times this month I have had my music start to cut-out while driving, it usually persists for 2-3 minutes and eventually the car just reboots mmi (folds screen up) on it’s own. Just curious if this happens to anyone else or if I should be planning a trip to the dealer sometime soon. It does seem to work fine after coming up but I’ve had the car about a year and it has only been doing this recently.... makes me think I’m about to get more use out of the warranty
    2013 DGP Audi A7 - Prestige/Sport
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Never had that happen in the 6+ years I have had my A6.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Try 'resetting your MMI. This typically helps clear some of the gremlins that pop up occasionally.
    To reset it, hold the 'menu' button, the center console button, and the 'northeast' silver button all at the same time. Your fingers will make a diagonal line from bottom left to top right.
    Kind of like a control-alt-delete maneuver.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Mar 10 2017
    Arizona
    Is that a different reset than its self-activated reset? I will give it a try tomorrow. Thanks
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by nks979 View Post
    No, it's the same. VCDS might reveal codes stored for any issues that would be causing it to reboot like that.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Oct 27 2013
    You say "music", your talking radio function or Bluetooth media streaming from your phone?
    Mmi updates are available, I have had two on my 2016 S6. Dealers by me are hesitant to apply them for issues they can't reproduce so if possible, figure out how to make it happen on command.
    Mar 10 2017
    Arizona
    Bluetooth streaming.
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by ryanlada View Post
    Did you have to pay for the updates, or were you able to get the dealer to do them for free?
    May 26 2015
    Mormon Country
    Quote Originally Posted by OlyS6 View Post
    Nobody works for free, especially at the dealer and even if it's warranty work.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Nov 22 2016
    Olympia, WA
    Ryan, how much did you wind up having to pay for updates for the MMI?
    Jan 02 2018
    Deleted
    It could be Bluetooth issues or MMI then. Somebody else posted similar problems and it was BT related, FYI. And I'd bet on that too. Did you change your phone recently? That person had trouble with his new Android phone on a 2016 car. An update solved it, so that's good news for you :).
    Mar 10 2017
    Arizona
    I doubt it’s the Bluetooth connection or the phone, idk why the car would reset itself when the fault isn’t in its system, iPhone 7 for the record
    Nov 22 2016
    Olympia, WA
    An issue I’ve run into is that MY2016 and later cars have the MOST150 fiberopric system, which has a 2way flow of information that includes a security feature- if the feedback isn’t what’s expected from the other components, the MMI will shut down. This could be due to an issue with the fiberoptics cable/s, or the oem amplifier. Mine has been shutting down because I removed the oem amp and the digital interface i have in it’s place isnt quite mimicking the OEM amp closely enough yet. Not your issue, but just pointing out that the issue could be with a downstream component in your sound system
    Mar 17 2018
    Boston, MA
    I had an issue with my 2016 S6 exactly as described. The issue only got worse as time went on. The key here is that the screen went down too, I'm curious if you notice that your center display does not shut off, but the digital information is not fed to it, when this happens as well. My issue ended up being the cable that connects the MMI system inside behind the dash board, there's like a C-clamp or something that fell off, and then as the car goes over bumps, the port cord slowly falls out or loose connection, and disconnects causing what appears to be a reset.
    Oct 27 2013
    Update was free.
    Removing and reinstalling my apr tune on the other hand... Pay to play.
    Nov 22 2016
    Olympia, WA
    Update was free.
    Thanks- my issue seems to be fixed with a firmware update to my digital interface- taking the car to the dealer would have been plan B. Good to know updates are available- thank you
    Oct 27 2013
    My issue was primarily with call audio but i had issues with media too. Update is better but i noticed today I was on a call and had a second ring in, the radio started playing for half a second and then call retuned. Overall it's 1000x better than it was and is now usable.
    Mar 10 2017
    Arizona
    Interesting, I hope that's not the cause as I really hate it when the dealer has to mess with trim panels... I don't remember the first two times but it did happen after a small bump this latest time.
    That was supposed to quote mike6, not sure why it didn't.
    Senior Member Two Rings tnjed's Avatar
    Jan 29 2018
    2023 Infiniti QX80
    Knoxville, TN
    Andre, this sounds much like an issue I am having. MMI sound frequently cutting out and not returning until the power cuts. It started happening not long after two things changed: I got the CarPlay added, and I upgraded the audio from stock Bose. I’ve assumed that the former was the cause ... but it sound like it could be the latter.
    Is the the digital interface you reference the Zen-V? If so, how have you worked around this problem?
