Results 1 to 11 of 11
    Senior Member Three Rings McTTRS's Avatar
    May 09 2017
    Alabama
    TT RS Maximum Tire Width?
    I am currently running 265x30x20 on the OEM wheels without any issues and it handles and rides noticeably better and am wondering if anyone has tried anything even wider and if so did they encountered any problems.
    2022, 2021, 2020, 2019, 2018 TT RS - 2016, 2010, 2019 TTS - 2006 Porsche Cayman - 2001 TT Quattro
    Junior Member Two Rings Culture's Avatar
    Aug 29 2017
    San Francisco, CA
    Here is a chart with wheel sizes and suitable tire widths
    http://www.tyresizecalculator.com/ch...rim-size-chart
    May 09 2017
    Alabama
    Quote Originally Posted by Culture View Post
    I was not clear in that I am planning to buy 19x9.5 wheels that will accommodate 275 width tires. Will the TT RS accommodate this combination without rubbing?
    May 26 2017
    East Coast
    Quote Originally Posted by McTTRS View Post
    Maybe this will help?
    https://www.wheel-size.com/size/audi/tt-rs/2019/
    May 09 2017
    Alabama
    Quote Originally Posted by davera3 View Post
    Not so much as this is nothing more than the OEM standard wheel and tire size options for the car. I am currently running 265x30x20 rubber on the OEM wheels and am wondering if anyone has tried 275x30x20 or 275x35x19 with any success. Thanks anyway.
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    I do understand the modding 'bling factor.' However in my own experience the worst mod's I've done over the years involved going with extra-wide tires. They significantly degrade the nimble response of sports cars/coupes, tending instead to 'railroad track', as well as the add'l weight. imho it would be a shame to degrade the superbly designed performance of the flagship TT for sake of such aesthetics. There, I've said my piece.
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Established Member Two Rings getsideways_'s Avatar
    Mar 10 2018
    WI
    Ill have 275s mounted soon I dont think there will be too many issues at that width.
    I planning to find a way to fit 300+ width tires on the car next year for track purposes.
    For street use I don't think anything that wide is remotely necessary.
    May 09 2017
    Alabama
    Quote Originally Posted by Huey52 View Post
    You have a good point and I appreciate your response. That said, I recently swapped out the 255 Advan rubber on my OEM 20" wheels for Michelin PS4 265s and the turn ins are much sharper and unlike the OEM rubber there is no hint of understeer. This has led me to consider at least 265 if not 275 rubber on a set of 19x9.5 VMR wheels I am considering to increase sidewall compliance in the turns as well as soften the ride. For me as a G junkie, it's not about looks but rather to increase the grip.
    Mar 22 2016
    Las Vegas, NV
    I’ve been running 275’s on 9.5’s since last summer and could fit 285’s and still not rub
    May 09 2017
    Alabama
    Quote Originally Posted by Lusky View Post
    Thanks.
    Apr 24 2021
    2008 911 GT3RS, 2018 R8 V10+, 2013 Mazda 3 hatchback, 2014 Toyota FJ Cruiser
    Murrieta, CA
    Does anyone have an experience running 19x10 rims on this car?
