Originally Posted by
f_399
Cool thanks!
Is it something they have to do even if you go in for an oil change?
I am scheduled for the recall but after reading this I don't want to do it unless they have the actual part.
I do need an oil change though, hoping its not something they have to do.
If you go in for ANY reason they will do the recall unless you decline it, and that's a whole 'nother bag of worms.
If you're still under warranty and aftermarket tuned, more than likely they will flag the car TD1. Only way I've gotten around this is to go to my local APR dealer and reflash the car to stock, then have the dealer do the work, then go back to my APR dealer and reflash the tune.
HOWEVER, none of the aftermarket tunes have coded out the aux coolant pump, so if Audi does the jumper plug mod to disconnect the pump and you go back to your aftermarket tune, you will get a CEL because of it.
TL; DR park outside if you're worried about the pump catching fire and don't want to do the recall.
