Alright let's get you filled in....
Driving the other day, and the light malfunction warning on my screen popped up. Got home and both headlights were out, just the lowbeams though. High beams, daylights, turn signals, and fogs all work.
My first thought was to check the fuses, since both went out at the same time. From checking the manual, online, back of fuse panel display, and all other sources, I still can not find the location of the fuse for the life of me! I said screw it and went ahead and pulled out every fuse on the drivers and passengers side to see if any were burned out, nothing. Came to the conclusion that there isn't a fuse for the headlights, and that they were either ran by relays or a control module somewhere else in the car. (unless I am corrected, which would be terrific)
Next check was to replace the bulbs. Did that and still no luck.
Would love to know the next move or if anyone out there would know the location to any fuse/relay/control module for the low beams?
Needed Info: It is a 2011 Audi A4 Quattro B8 Manual Transmission. My headlights are ran with halogen bulbs, not hid or xenon lights. I also do not have the auto adjusting/height adjusting headlights.
