The transfer box/case/bevel box failures seem to fail much more frequently on tuned vehicles......
"Transfer Box Test
Make sure you are capable of doing this in a safe manor.
You are in control of your own safety. We are not liable for any damage or harm you may cause yourself, your workshop, other people, or your car. This test is only for automotive repair professional use only.
Lift the car so the front wheels are off the ground.
Get somebody or a camera to watch the propshaft.
Someone else to sit in the car, starts up the engine.
Apply foot brake, remove handbrake, put vehicle into drive gear.
Then very gently lift your foot off the brake so the front weeks start to turn.
If the prop shaft is stationary then the transfer box is faulty.
If the prop shaft rotates then you have a Haldex issue.
Transfer Box Failure generally only effects modified vehicles, almost every example has been a remapped car. Very common with Golf R, S3, RS3, TTS, TTRS etc. These transfer boxes are not designed to be robust, this is a really good youtube video showing how they fail inside https://www.youtube.com/watch?v=nt33-EgQ4gk"
Taken from the masters:
https://www.haldexrepairs.co.uk/gene...-repair-guide/
