Originally Posted by
skree25
My pump doesn’t prime with key to on. Can you jump the fuse to verify the pump has power jic? Reverse polarity had my wires crossed when I installed my new pump which caused some headache on new engine startup
Sent from my iPhone using
Audizine
Thanks for checking, that could be good news. I may not have a problem then. I've bypassed the relay all together and everything operates as it is intended. I have also opened the fuel pump relay to check for corrosion and the like, everything looks brand new. I then reinstalled it with the cover removed, turned the key on then activated the relay manually. It operates as intended. This leads me to believe that the ecu isn't sending the proper signal. It will click (I can hear and feel it) extremely fast when the key is turned to on/engine off but not enough to actually trip the relay and send the power to the pump. When I measure the ground output to the relay from the ecu I am getting a constant signal (not an intermittent as I expect a prime signal to be) but not enough to trip the relay. After reading your post and the ones that follow it looks like cranking the car is the key here.
slowSfaux
I tried to narrow down under what circumstances the fuel pump actually primes with the key on, and wasn't able to repeat 100% consistency. 80% of the time it will prime during the first key on cycle after sitting overnight (8+ hours shut off). Outside of that, the pump will prime about 20% of the time on a hot restart. I don't understand why it doesn't just prime every time the ignition is switched on, but nonetheless, your fuel system is probably fine. After having the battery disconnected for awhile, my fuel pump sometimes won't prime at all until cranking.
Thanks for trying and it seems to confirm somewhat of what Skree25 is experiencing. It has been so long since I have driven the car I cannot recall if it primed every time or not.
julex
Well, during cranking it must prime/run as otherwise your car would not start at all. And if it doesn't then there is something wrong with the electronics/electrics. Most likely relay or the pump is simply blown. Blown pump is usually running in a capricious manner, one time it does, the other it doesn't
I am beginning to think that I am chasing a non-existent issue. I am not at the point where I can crank the car to see if the signal appears but suspect that may be the case. As stated, the car ran fine when it was torn down, the relay has been checked along with the pump wiring. Barring an ecu problem I may be wasting my time.
Thanks for the replies so far and the effort in checking your cars. I suppose I'll stop worrying about it for the time being and get to the point where I can actually crank it over to see if that solves my problem.
