Results 1 to 11 of 11
    Senior Member Two Rings aFOURstance's Avatar
    Jan 30 2011
    '04 DBP R32 PTE6266 Turbo, '01 Nogaro S4 Stg 3 & Bagged
    FAIRFAX, VA
    Disabling "Cylinder On Demand"
    So it seems like this feature puts a lot of stress on the engine mounts. I recently scanned my car and got a code to replace the mounts. Since I'm no longer under warranty this expense will come out of pocket and I would like to see if anyone here has the means or resources to disable this COD feature to prolong the life of the new mounts that I'll be installing.
    I have VCDS but from what info I've gathered only tuners have access to this particular function.
    Thanks in advance
    Life is too short to drive boring cars.
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    Quote Originally Posted by aFOURstance View Post
    Thanks in advance
    Just drive aggressively all the time
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    What is your basis for COD destroying mounts? Audi is legendary for terrible mount designs that fail prematurely. Get the 034 solid mounts and I bet you never have to do it again.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Oct 14 2006
    Rocky Mountains
    I got lucky. When I had my S6, one of the motor mounts went at 45k miles. Dealer replaced both as a precautionary measure under warranty.
    Jan 30 2011
    FAIRFAX, VA
    Quote Originally Posted by lnferno View Post
    No kidding haha Dynamic mode all day everyday!
    Quote Originally Posted by GilliamOS View Post
    Sorry I failed to mention I have a C7 S6, and they dont make aftermarket/upgraded mounts for ours
    May 26 2015
    Mormon Country
    Ahh well poop. Those are some crazy looking mounts and they are spendy!
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Jun 30 2016
    NNJ
    And make a luxury car vibrate like a hoopty? No thanks.
    May 26 2015
    Mormon Country
    Quote Originally Posted by MadMaxD View Post
    I had the street density version on my B5. The NVH level was no different than the comparatively stiffer OEM V6 mounts (vs 1.8T) I had used prior that had also failed.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Dec 17 2017
    Louisiana
    I can disable COD temporarily with OBDeleven on my C7 S6. Two problems: The engine light activated and it reverts to the original setting when the ingnition is turned off.
    I am going to try to find a permanent tuning solution and notify later.
    Sent from my Moto G (5) Plus using Audizine mobile app
    Jan 30 2011
    FAIRFAX, VA
    Quote Originally Posted by uBu View Post
    Definitely share when you find a permanent solution, thanks for chiming in
    Jan 02 2018
    Deleted
    It's well documented. Engine vibrates a lot under COD, so mounts 'fire up' every crank rotation to quell the vibes. Without COD, they'd last way longer. What craps out is the membrane holding the fluid, which fatigues from overuse over time, apparently. I'd also like to disable COD, but seems only a tune can achieve that, which I will not do under warranty.
