Hello Everyone,
Another day another issue with the B6 it seems. #B6Life
All the details on my latest issue are below:
Car Background:
2004.5 Audi A4 1.8T Quattro with nearly 200K miles. I live in Austin, TX (warm climate) and the car is daily-driven. Just recently changed out thermostat, water-pump, and performed a coolant flush to resolve a coolant leak I had over the winter. Also, replaced alternator and a few other odds and ends recently. Overall, car has been running fine.....for about a month until this new issue started.
The Issue:
I currently have a slight odor of gas in the garage AND in the interior of the car after I fill-up with a FULL tank of gas. It appears to be coming from the rear driver's side area (close to the rear driver's side wheel well area) where I can slightly smell it. The smell starts to fade as I get closer to the 3/4 and 1/2 mark on the fuel gauge (the more I drive the car).
To assist in the troubleshooting, I have noted the following so far:
-Slight gas smell after I fill-up and have a full tank of gas.
-No CEL for gas light.
-Able to fill-up without issue (gas pump does not click-off or stop intermittently).
-Smell fades as it gets close to the 3/4 mark on the fuel gauge.
-N80 Valve replaced in September 2017.
-Fuel Filter replaced in April/May 2016.
-Fuel Pump Seals REPLACED (Drivers and Passenger side) in May 2018.
Possible Cause:
Doing some searching I've found a few posts on the subject. Specifically the following:
1. https://www.audizine.com/forum/showt...when-full-tank
2. http://www.audizine.com/forum/showth...ses-LDP-itself
3. https://www.audizine.com/forum/showt...n-tank-is-full
It sounds like it could be a leak somewhere, but my symptoms above don't really match anything like those connected to the evap system or charcoal canister so far.
If I can provide any additional details from my end to assist in the troubleshooting process, please let me know. If anyone has any ideas / feedback / thoughts /etc. on what the possible root-cause of the issue is, it would be greatly appreciated!
Thanks,
Asif
