Results 1 to 4 of 4
    Senior Member Three Rings Darel's Avatar
    Mar 27 2018
    Mountain Top, PA
    Difference between "Audi CD Changer" and "Audi Multimedia"
    Shopping for B8 S5s right now and I am seeing cars with both things written on the head unit in the center stack.
    I have searched around and I can't quite figure out what the difference is.
    One car is a 2009, completely loaded with every factory option except adaptive cruise, and it says "CD Changer".
    Other lower spec cars sometimes say "Multimedia".
    I've never come across a car with the radio buttons up on the stack, for either one they are always down by the shifter (I read somewhere that's a sign of the early units that you don't want).
    If it says "CD Changer" can I assume it does not have the SD card slots under the flap?
    Or does "Multimedia" indicate the ability to play DVDs?
    I do know that cars that say "CD Changer" still have the MMI in the glove box.
    Or did they just change "CD Changer" to Multimedia" one year because CD changers are sooooooo 1997 and that little placard doesn't actually indicate a change in equipment?
    Sorry..I tried starting a couple of different threads on this but still can't quite nail down a specific answer to this question.
    Thanks,
    D
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    If cd charger is above climate control, it should be mmi 2G, multimedia unit in same place is mmi 3G(in US i think it started from model year 10). Both systems have buttons around gearshifter!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Mar 27 2018
    Mountain Top, PA
    OK, CD Changer = 2G and Multimedia = 3G. So again what does that mean? I am still not clear on the features of 2G vs. 3G.
    Thanks,
    Darel
    Mar 27 2018
    Mountain Top, PA
    Disregard, I found a link to a wikipedia article. Never thought to look there. Had a handy chart that shows all the different functionalities. So "CD Changer" = 2G and does not have SD card inputs, HDD, BT streaming or DVD. Perfect, that's what I needed.
