Results 1 to 18 of 18
    Established Member Two Rings khawari's Avatar
    Apr 16 2018
    Ottawa, ON Canada
    Just got a 2002 Audi A4 I want to understand the upgrades
    So I just bought a 2002 Audi A4 and it came in super mint condition not a spec of rust or dust and 160,000km mileage... It also had pre-installed Non-standard part list. I wanted someone to explain to me what each one is please if you do not mind. Still a new car owner and excited to learn! Thanks
    -BB catback stainless exhaust
    -304 Motorsport billet PCV
    -ECS Tuning billet thermostat
    -ECS Tuning silicone hoses
    -RS4 rear sway bar
    -Neuspeed short shifter
    -Neuspeed snub mount
    -TT diverter valve
    -2.0T ignition coils with billet adapters
    -Bosch (TT) 250cc injectors
    -Tapp stage II tune
    Thanks again
    Kal
    Sent from my Phone using Audizine mobile app
    Jul 14 2009
    Pasadena
    Quote Originally Posted by khawari View Post
    Thanks again
    Kal
    a billy boat downpipe back exhaust system
    -034* Motorsport billet PCV
    check valve that commonly fails that 034 made a metal billet version of
    thermostat that was plastic that ecs made a metal billet version of because it commonly failed also
    usually these are hoses leading into and out of the turbo. standard hoses collapse under pressure. could also be an intake hose
    -RS4 rear sway bar
    to help control the crazy amount of understeer our cars have
    to give u a better hand held shifting experience with shorter more precise throws of the knob
    the mount your block basically connects to the subframe. tightens up the driveline feel
    -TT diverter valve
    think of this like the boost valve. the standard ones fails under tuned added pressure so people commonly upgrade to the tt one also commonly called 710n valve
    these are slightly longer coilpacks that go over your sparkplugs and need adapters to fit in the extra height. they allow for a colder and better spark
    these are commonly used in stage 2 tunes and come off a tt
    -Tapp stage II tune
    never heard of this brand but like all stage 2 tunes your ecu tune has probably made your car 1000x more fun.
    Welcome to AZ. I encourage your next to just do a simple google search of your questions and you will the sites where all those products are sold with exact descriptions of what they do. The b6 section in particular has a plethora of information and you just got to search for it sometimes. But believe me, its all there.
    IG: @matthewee
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Aftermarket exhaust
    metal pcv
    metal tstat
    hoses that aren't rubber
    -RS4 rear sway bar
    bigger sway bar
    shifter with shorter throw
    upgraded mount
    -TT diverter valve
    diverter valve from a TT
    ignition coils from a 2.0t engine with adapters made from metal
    Bigger injectors
    -Tapp stage II tune
    an ecu tune
    Thanks again
    Also, the earth is spherical, JFK assassination was not a conspiracy, and Hillary belongs in prison.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Apr 16 2018
    Ottawa, ON Canada
    Thanks :D I'm so extremely excited to be a part of the audi family! And this forum!
    Apr 16 2018
    Ottawa, ON Canada
    Quote Originally Posted by redline380 View Post
    Amen!
    Veteran Member Three Rings fabric8's Avatar
    May 14 2013
    US
    Quote Originally Posted by itsmatt33 View Post
    thermostat that was plastics that ecs made a metal billet version of because it commonly failed also
    usually these are hose leading into and out of the turbo. standard hoses collapse under pressure. could also be an intake hose
    -RS4 rear sway bar
    the most your block basically connects to the subframe. tightens up the driveline feel
    -TT diverter valve
    -Tapp stage II tune
    Kudos to itsmat33. Its members like you and responses like this that make AZ an awesome forum. I wish this etiquette existed over on vwvortex.
    HIS - 2016 Golf R 6MT
    HERS - 2002 B6 A4 1.8TQM Avant | Motoza Stg.1.5 | OEM A6 4.2 17" forged fat fives
    May 27 2016
    Westchester, NY
    Should be pretty peppy.
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    Nice to see another canuck on the b6 section
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Also, the earth is an oblate spheroid, JFK was a great president, and Trump will end up in prison.
    Edited for accuracy
    Apr 16 2018
    Ottawa, ON Canada
    Quote Originally Posted by IndoReef View Post
    Haha what's a Canuck?
    Apr 16 2018
    Ottawa, ON Canada
    Quote Originally Posted by fabric8 View Post
    Itsmat33 was very helpful. Thanks for the info. I know I should Google more but I'm a total noob when it comes to car parts and abbreviations. I guess I got too excited with the thought of owning this few car and brain farted real hard.
    Cheers
    Oct 29 2005
    10speed
    San Francisco, CA
    FYI a "Tapp" tune is Eurodyne, a reputable tuner in Canada.
    - Clint
    Nov 15 2011
    Montreal | I sell in USD
    Qft
    *****I sell in USD*****
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    Kal, let me know if you need anything scanned on your car. I'm in Ottawa too and have a few B6s on the go.
    I'll need to get an updated picture, as two more have been added to the fleet since.
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Veteran Member Three Rings pablolizarraga's Avatar
    Jul 18 2014
    "Hers": SQ5 His: 1966 Ford Mustang Coupe, 1965 Ford Mustang Fastback
    Los Angeles, CA
    Quote Originally Posted by Gosser View Post
    Moar pics, w/ suspension/wheel/tire specs, of that black A4 please. Now you got me re-re considering wheel choice. Going back and forth between S5 Rotors or Peelers. Chrome trim and mirrors make perfect compliment to those wheels.
    And OP, welcome to Audizine community.
    Jun 05 2013
    Ottawa
    Ask and you shall receive:
    Just realized they were all ass shots, heres a front:
    They are B8 S4 peelers, 19"x8.5" ET43 wrapped with 255/35/19. But they are gone, and its riding/stored on some sewer caps for the moment, while I get some S5 peelers refinished. The S5s are 19"x9" ET33 wrapped in the same. They have the offset I'm looking for without the use of spacer and are more concaved. Should have it all out and ready for the end of the month, cant wait really!
    Suspension is all OEM S4 gear, with the exception of the some B5 perches in the front(3/8" drop about). No spacers.
    2007 RS4 Avant
    Jul 18 2014
    Los Angeles, CA
    Nice! Looking fwd to pics of the upgrade! Surprised 255’s on 19’s actually fit.
    S4 rear bumper have that aluminum trunk trim? Looks good.
    Jun 05 2013
    Ottawa
    Yea, there is no doubt it is tight! Now that I think about it, it did rub one the knuckle a bit. I wouldnt do it again, but it was temporary to get me through the end of the season, and the tires were already pooched.
    This is my silver A4:
    The silver A4 has RS4 rep wheels(has Audi center caps) is 19"x8.5" ET38 with 255/35/19 and no issues at all. I should mention, my S4 rubs on big dips in the road at the front upper fender screw. But no where in the back, or when locked during turning. I will be removing the screw for the S5 peelers and have no concerns that they will hit the knuckle. I have yet to experience any rubbing with the A4 that is on the OEM sport suspension.
    I've also never seen a non aluminum trunk trim from the factory. Only reason I havent blacked it out is because it matches the windows.
    2007 RS4 Avant
