Results 1 to 40 of 48
    Apr 11 2017
    Calgary
    Is there a bigger throttle body other then ultra charger
    Just wondering if there are any companies that make a larger throttle body ? I had heard that a few companies that were working on them. I have a giac tune so the ultra charger won't work for me. Thanks
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    A larger throttle body will require a special tune, so that won’t work for you either.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Oct 02 2005
    The Moon
    Quote Originally Posted by infinkc View Post
    Not true. A few guys have swapped out their 80mm Ultracharger TB for 85mm and 90mm without issue.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by p3u View Post
    But that insinuates they already have an ultracharger tune in the first place...
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Oct 02 2005
    The Moon
    Of course. But the Ultracharger charger tune really just allows the Hemi throttle bodies to communicate with the ECU properly. The ECU can adapt to airflow from a larger TB, just need one that can talk to the ECU.
    Veteran Member Four Rings rtl5009's Avatar
    Jul 28 2009
    Philadelphia PA
    I have a potted and polished TB. It’s slightly larger.
    b5 s4 built bottom stg3 on E - Sold- Never felt happier
    c8 a6 allroad
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Anyone running a larger throttle body with Unitronic tune?
    Senior Member Two Rings jcpowell's Avatar
    Oct 18 2017
    Somewhere, GA
    What are the benefits behind a larger throttle body? It seems like people with the ultracharger aren't reporting any noticeable differences over Stage 2 DP.
    2018 Brilliant Black S6 Prestige | APR Stage 3+TCU & downpipes | SRM RS7 Turbos | H&R Sway Bars | RS Grille | Sport & Black Optics Package, Alcantara Headliner
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    Issam and 1 other company are working on/have developed larger TB's, in addition to APR, and they are in final stages, before release ( supposedly).
    The stock TB is a half in smaller in diameter than the intake of the supercharger, as well as losing the space occupied by the butterfly valve. So, the idea is to remove this airflow bottleneck.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Oct 18 2017
    Somewhere, GA
    Quote Originally Posted by brs2c View Post
    Serious question, but does that half inch really make a big difference in terms of air intake volume? So if you got a bigger throttle body than that then you would also increase the diameter of the supercharger intake?
    Apr 26 2017
    GLS 450
    Nashville, TN
    An extra half inch makes a big difference when you are talking area of a circle. I think APR's TB may be smaller than what others are making, as UC is only 25% larger than stock. Here's the math, at work.
    3"diameter circle= 7.07 sq inches
    3.5"diameter circle= 9.625 sq inches
    So, 3 to 3.5" increase is a 36% increase in diameter (on the yet to be released versions).
    Previous
    Oct 18 2017
    Somewhere, GA
    An extra half inch makes a big difference when you are talking area of a circle. In this case, a half inch gets you 25ish% more area.
    Thanks, just trying to gain some understanding.
    Apr 26 2017
    GLS 450
    Nashville, TN
    Quote Originally Posted by jcpowell View Post
    I just updated with more detail in my previous explanation. There are actually a couple of benefits from the larger TB. First, because air is more easily sucked in, more comes in ( so more power)- like drinking a milkshake from a bigger diameter straw. Second, because volumetric efficiency has been increased (you are moving more air through the engine, in a given period of time), the air takes on less heat making more power (lower IAT'S )- like a larger diameter straw increases the risk of brain freeze.
    You likely understand all of this, but I post in case it helps someone grasp the concept of why the larger TB's are good. I expect the larger ones to help more than the UC, once released.
    Previous
    Nov 28 2015
    Montreal, QC
    ^^ Once it release, it will take more times ( maybe 4-8weeks) before official tunes get released.
    In theory this is what it is, in pratice, people with UC have noticed better throttle response and less '' lag'' to accelerate when driving around 2k and accelerating full throttle instantly. It's not huge, but when your already DP, theres very little left to do on the car performance-wise... soooo you take better throttle responce over nothing :D
    S4 B8.5 no track, just enjoying spirited driving.
    Sep 22 2013
    Tunerwerks has a TB tune
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    Its a mod that plays very well with ported superchargers as well. With a larger throttle body and ported supercharger guys are reporting an extra 2-3mph on traps and that the car feels much stronger to redline.
    With more companies doing R&D with even 90mm throttle bodies I hope we'll see more hard data on the subject.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    A plug and play larger TB with matched "noodle" would be awesome. If someone made that they would sell. Part of the issue with APR is your not APR tuned your cannot run it. That approach limits what portion of the market is interesting or can us your product. Their hope is you would change tunes but so many trust what they have they wont.
    Time will tell but it would be nice to see.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    I brought up this topic on the 3.0T Technical facebook group (click in my sig to join, its a group who wants to continue development on the platform and sharing pretty much all of their findings and solutions along the way). There are options out there ranging from 83-90mm that is a direct swap (meaning no ECU re-calibration needed) for those who already have the program to run the 80mm unit.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Established Member Two Rings fx_warrior's Avatar
    Sep 18 2013
    Bronx NY
    Once released is the biggest part here. Everyone gets on APR's case for how long they take, well there have been 2 other people who said they're coming out with a competing TB and I saw them saying this many many months ago. If not close to a year now.
    Sep 18 2013
    Bronx NY
    Quote Originally Posted by waxxonMTL View Post
    Lol you and your snark comments anything APR.... guys are trapping over 120 on 93 files lol. That's a little more then just better throttle response.
    Jan 04 2013
    Phoenix, az
    I don’t have Facebook so I guess I will have to hope it gets shared here!
    Jan 03 2018
    South Carolina
    Think a lil outside the box go look on the supercharged Mustang, Corvette, Cadillac forums and Magazine articles there has been a lot of research done on the gains. It has been proven that 3% increase in size shows WHP gains. I think the best thing is overall cost per HP when compared to porting your supercharger.
    2014 S7
    2012 Oolong Grey A7 | DP 91-104 tune| Merc Hx| 57/187mm| Cat delete| Magnaflow x-pipe| ported SC TOTALED
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by rtl5009 View Post
    you're GIAC correct? what size/brand did you get (if you don;t mind me asking) and do you feel that its worth it?
    i think you and i have similar setups if i remember correctly
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Apr 26 2017
    GLS 450
    Nashville, TN
    With regards to the timing of other's release (yes multiple companies are on this)- I was bitching about "how long should it take for a motivated and capable fabricator to produce this!?" I am not going to name names, but I was told by an someone witha close relationship to a developer, that release delay issues have been related to the fighting of another's patent approval, on which the R&D on has been done for a while...I am not involved in this, IDK what this guys source was, and I could have been told a pack of lies...BUT it would explain the long delay on a reasonably simple mod.
    Previous
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Quote Originally Posted by KRp220 View Post
    I'm also interested in TB mods that can be used with GIAC DP tunes race/pump files
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Apr 05 2016
    Portland, OR
    You can't go too much more aggressive on the stock TB than this.
    I need to trim down my meth plate, it is now the most restrictive part of the intake.
    Geoff
    Oct 02 2005
    The Moon
    I've started on my own larger TB in hopes for plug and play. With a little luck the harness I'm putting together will communicate correctly with the ECU and allow a TB adaptation.
    I should know in the next day or so, just need to purchase the wire to construct the harness.
    Apr 04 2017
    Chicago IL
    Quote Originally Posted by PeteRock View Post
    On a positive note I spoke to Issam today and he said that his Throttle Body will be released in about a week....not 100% sure if that’s actually a week but I would bet that it will be sooner than the 2 weeks it was supposed to be until B8.5 program switching was supposed to be released about 2 years ago!
    Pete
    From the ultracharger thread... Things are getting interesting again.
    Veteran Member Three Rings friskuh's Avatar
    Jul 31 2017
    Orlando
    Quote Originally Posted by Loe View Post
    What are the bigger options? Can you list some if you don’t mind?
    Mar 20 2015
    McKinney,TX
    I’m coming by this weekend to check it out, ready or not!
    Senior Member Three Rings trip'n's Avatar
    Dec 28 2009
    2000 B5 S4
    plug and play up to 90mm TB on the Ultra files sounds kinda good to me, Chrysler as well?
    Active Member One Ring jwye120's Avatar
    Feb 17 2017
    2007 HD Nightster
    Milwaukee, WI
    Looks like a typo in your last sentence because you obviously get the math. I think you meant 36% increase area with an increase from 3" to 3.5".
    Jan 04 2013
    Phoenix, az
    I just don't get this proprietary approach everyone is taking on developing these larger TBs. If ELP, GIAC, E34 or whom ever comes out with one and it requires me to use their tune I am not buying it. I am happy with my tune and the amount I have invested. Now if they came out with a plug and play I would buy it.
    Seems like they have lost site of the marketing approach of get customers buying and using your products, they will probably buy and use more of them if the experience is positive.
    Apr 04 2017
    Chicago IL
    You're dead on. However there are so many of us willing to pay these bloated prices for an average experience that they've gotten away with it relatively easily.
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by friskuh View Post
    they are just 5.7-6.4L (2005-2012) TB's that are available as aftermarket upgrades for that platform that range from 85-90mm. On a side note, if you remove the throttle plate rod on the backside on the 80mm OEM hemi TB, you have approx 4mm back; basically a freebie mod that a few Hemi guys do...I spent a bit on those forums (and others) to get idea's on what to do next to see how much further the blower can be pushed.
    Jul 31 2017
    Orlando
    & those are plug & play on our platform? It hooks up directly with no electrical hassle?
    Apr 26 2017
    GLS 450
    Nashville, TN
    Just posted this in the UC thread, but thought it should be here for future searchers:
    I ran across this explanation on the FB tech forum:
    "Another TB, however, changes the volumetric efficiency of an engine, which for a MAP based ECU like ours is a drastic change. To tune for other TB you need to alter AR_RED_BAS table in the picture I've attached. "
    https://scontent.fbna1-2.fna.fbcdn.n...10&oe=5B6DCC39
    Another thing to keep in mind is that our cars' tunes consist of thousands of engine files that encapsulate all the various settings of fuel, air specs, RPM, etc. If you go into an area where the files necessary to support the engine's newly increased performance don't exist- you are SOL for taking full advantage of the mod.
    Previous
    Jul 31 2017
    Orlando
    can you post a link to the UC Thread?
    Jul 31 2017
    Orlando
    Did they share their findings? if so, do you mind sharing what thread it’s on? I can’t find it anywhere.
    Active Member One Ring Wazzap1101's Avatar
    Sep 13 2013
    Long Island, New York
    Interested in those larger TB options that was brought up earlier in the thread
    Sent from my SM-N960U1 using Audizine mobile app
