Results 1 to 16 of 16
    Oct 10 2016
    Colorado
    Oil pressure switch replacement
    I've been getting the "Switch off engine! Oil Pressure too low" warning. Dealer says I need a new pressure switch. What part and what's the typical cost for replacing this?
    Any DIY article available?
    Thanks.
    Senior Member Two Rings intplayboys's Avatar
    Jul 20 2005
    Real easy to do. Part at the dealer cost about $20-30. Forgot what size socket, just make sure it’s a deep socket. It’s next to the oil filter. Should not take you more than 10mins to change. IMG_1253.jpg
    Oct 10 2016
    Colorado
    [QUOTE=intplayboys;13050463]Real easy to do. Part at the dealer cost about $20-30. Forgot what size socket, just make sure it’s a deep socket. It’s next to the oil filter. Should not take you more than 10mins to change. IMG_1253.jpg
    wow! I was quoted $418 for this!
    "Replace F378 Reduced Oil Pressure Switch (038 919 081C) - $418"
    So this is the only pressure switch that send the message or are they referring to something else?
    Thanks.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Jul 20 2005
    Yup...just gotta get the right color..brown/blue. Depends which you have on the car.
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by intplayboys View Post
    Both are on the car...the brown is the reduced pressure switch and the blue is the oil sender located a bit lower.
    2011 A4 Avant
    Oct 10 2016
    Colorado
    Quote Originally Posted by jfo View Post
    So how would I know which one to replace? any advise?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The dealer gave you the part number for the correct switch.
    Dec 13 2015
    Too%20many%20
    PA
    Slightly off topic, but... anyone know how that connector gets removed from the switch itself? When I pulled the intake to decode my valve stems, I couldn't figure out how to remove the connector. Squeeze the tab with the notch in it?
    Oct 10 2016
    Colorado
    Quote Originally Posted by Justin B8 View Post
    Looking at the part, seems like there's one side that locks into the plug. I would suggest squeezing the connector or pry it off with a small screw driver? Haven't done it yet as I'm still waiting for the part .
    Dec 13 2015
    Too%20many%20
    PA
    Quote Originally Posted by eclipse1 View Post
    Tried all that; didn't want to break it. Pls let me know how you remove it, lol.
    Nov 17 2010
    It's a common style connector. There's a small tab with a slot in it at the top. Gently pull back on that tab which lifts the internal lock tab and releases the connector. With the other hand pull the connector free.
    2011 A4 Avant
    Dec 13 2015
    Too%20many%20
    PA
    Thanks; doing chains/guides/tensioners in about a week, will give it a go.
    May 22 2017
    Wilmington, MA
    Best way is with one of these: https://www.ecstuning.com/b-schwaben...BoCFUEQAvD_BwE
    Be alert! America needs more lerts.
    Eric Law
    '14 A6Q 3.0t prestige self-tuned
    '12 A4Q also self-tuned
    Dec 13 2015
    Too%20many%20
    PA
    Quote Originally Posted by ELaw View Post
    Thanks. Added to the cart for next order.
    Oct 10 2016
    Colorado
    It was very simple actually. look at the pic above. you see the opening on the top part of the black connector? slide a flat screwdriver or even a key and pry it up gently, the connection will release as you pull up.
