The wheels are 19x9 Enkei RSM-9 wheels with a 50mm offset. I went that route so I could use some small spacers to tailor the fitment. Using a 3mm spacer on the front and a 5mm on the rear its a snug fit but everything clears. I'll be putting camber plates on the front shortly so that will only help. Currently my car is not lowered, I may do a slight drop if I upgrade to the MSS springs at which time I'll have to watch the small plastic piece mounted to the back of the rear wheel well.
The good news is that once I wear these out I'm confident that a set of 265/30/19 Toyo R888R tires will fit with no issues!
Fronts:
Rears:
