Hey Gents!
I'm happy to respond to this! I had a 2012 S5 (tiptronic) which I recently traded in for a 2015 RS5, and when I was looking for information, there was very little. I combed through the forums dozens of times looking for info on how to boost the power on the NA V8. Everyone had their opinions on mods and how their was 'very little to no power to be gained', 'mods aren't accumulative' & 'where's the dyno'. While I'll admit, I never had a dyno done, I can tell you from first had experience that the exhaust + tune + intake made a substantial difference. On a few occasions I was able to race my brothers E92 M3 from a roll in 2nd gear and was able to keep up (he did begin to pull away at higher speeds).
I had the V8 S5 for 4 years and did the following mods, over 3 years:
1. AWE Touring Catback
2. AWE Non-resonated downpipes
3. AWE S-Flo intake (non carbon)
4. Had a
'Stage 2 tune' built by REVO, which I had to send them my factory ECU settings. The 2.5" exhaust and intake were required for this map and they stated a gain of 15hp and almost 20ft lb torque, but a nice increase in overall power throughout the curve.
Regarding the tune, I bought an SPS 'switcher' in which you could change the tune back to a 'factoryesque' setting, and it would store 3 performance modes which you could manually set on a computer. You could also adjust throttle response, timing and the fuel you're using (richer, leaner). I had my timing set to 6, throttle set to 9 and fuel set to 94octane (99RON).
Performance wise, the largest gains were from the intake, and then the tune. I could feel a large difference adjusting the timing back to 'stock' vs. the most aggressive setting of 6. Anything above 6, and you were to use race fuel. The car, which previously felt sluggish and extremely lacking into 2nd gear, felt completely different. Throttle response was much better, and as someone previously mentioned, way more responsive in the mid-range. I actually came across JHM after I had already purchased my tune, but from what I've read, I'd go with JHM's tune regardless of which exhaust you've got. They have ton's of 1/4 mile times posted, which are shaving anywhere from .5 to 1 second off stock times (though, that's with test pipes)
To even further prove that the intake is a good upgrade, I ended up getting a CEL after the install. I took it to Audi to diagnose the problem, and they noticed that both banks were 'running lean' and were recieving about 20-30% more air. The ECU was compensating by dumping more fuel, so I ended up adjusting the setting to have the tune run a bit more rich. In the end, the CEL was caused by the MAF getting a little dirty from the wet filter, but proof that the intake really drove more air into the system.
I do believe the RS5 is faster than my old S5, but to be honest ... I don't feel like it's a night and day difference. The cars drive different, my S5 had way more torque and I'm still adjusting to really winding out the RPM'S on the RS5 to make use of that 8250 redline. The RS5 also makes peak numbers at like 7600 RPM. I'm hoping for more torque (which I miss from my S5) and for now I ordered the JHM 2.75" exhaust and am patiently awaiting their tune for hopefully even more power!
If you have any more questions, feel free to PM me as I went down this path and did basically every upgrade besides JHM's supercharger for the S5.
