a4 B7 Quattro w/ 180,000 miles. I have been burning a crazy amount of oil in the last 10k miles, like 3 qts b/t oil changes. I was told to possibly the PCV valve (which I replaced 2 years ago), and to check it by opening the oil cap on a running engine: 'If you can't remove the cap then the PCV is not working.' Well there was slight suction on the oil cap not nothing to difficult, but the engine immediately began running really rough with the cap off. Does this still indicate PCV Valve?
