Results 1 to 11 of 11
    Apr 07 2018
    Topeka ks
    Rebuild or replace engine? 2.0t bpy
    Hey guys. So long story short, I bought a 08 audi b7 quattro 6spd with a 2.0t bpy. Has 117k on it, bought it out of state 4hrs away, it made it back fine then the oil cooler or gasket shot shit. Replaced both then i had a massive oil leak near oil filter housing, first thing i did was pull the oil filter and it was completely collapsed. replaced filter and added oil.. not a leak since. Still had my oil pressure light come on and I ended up dropping the pan to find the clogged pick up tube along with the seized balance shafts and the snapped bolt on balancer side. I dropped 2 connecting rod caps and the bearings looked normal for 117k. Now I bought a new pump and replaced pick up tube with a new one. Still had the oil pressure light. I had 5w30 in it so I bought mobil1 0w40 and went to drain that 5w30 and found excessive metal shavings. I believe it's time to pull the motor. Now my question is...
    Should I get my current engine rebuilt or swap in a used engine? I found a few engines price range around 200-400$. All the engines i've found are from automatics. If I go ahead and just put a used motor, of course I'd replace pick up tube and all timing components along with some gaskets. I've read that I'd have to swap all my sensors from my current motor to the replacement.. but makes no sense.. Because if I where to replace all sensors with new sensors it should still start.. I just need some input.
    If you want to see the oil shavings and my b7 here's my youtube channel:
    May 20 2010
    I'd replace it with one you know was working, or make a known working one. I'd be wary of anything that has seized. If you can find a special edition/DTM (engine BUL), it has some stronger internals. See this link: https://www.audizine.com/forum/showt...ne-do-you-have
    Btw, BPY is in VWs or an A3. If you have an 08, you more than likely have a BWT.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Apr 07 2018
    Topeka ks
    Thanks for ya input. The previous owner said he put a "new" head on it.. how do I tell if the block is BWT??
    May 20 2010
    I know it's stamped in there somewhere, but I forget where. If this was Friday, I could tell you, but I just sold the engine.
    Feb 15 2016
    Cambridge,Ontario
    It should be on a sticker on your timing belt cover
    Its also on a bracket on top of the engine somewhere
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Dec 05 2016
    miami FL
    200-400 for an engine. why did i pay 2000 and 400 to ship on top of it. thats dirt cheap, wouldnt ya agree?
    Jun 17 2013
    jersey city nj
    Automatic tiptronic will not into a manual. The crank is different. You will be able to use a automatic cvt engine thou.
    Apr 07 2018
    Topeka ks
    So if I can't find one out of a cvt or manual would rebuilding my current motor be the best route? Still runs and drives.. sounds solid but I'm not going to push my luck and drive it
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by Pres View Post
    Honestly, the best way to answer your question is to pull your current motor, strip it down and examine it for improper wear. If it is serviceable, use it. If not, get a used motor.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by ahotboy15 View Post
    This. Where are you finding 2.0 fsi engines for so cheap? I'll buy a couple at that price. I paid $250 for an engine with a blown oil pump and a seized head to rebuild for my car. From what I've seen, you can't get a working fsi motor for less than about $1500 from most places and that's generally for a high mile one. Are you sure you are looking at the correct engines? I don't even think 1.8s are that cheap.
    -Adam
    Dec 05 2016
    miami FL
    engine for that cheap must prolly need a complete rebuild?
