Results 1 to 2 of 2
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    AMB ignition coil wiring diagram, wire colors, pin out
    Anybody have the wire colors and pin out for ignition coils? Need to rewire the coils of AMB engine.
    Pin 1 = 12V, Pin 3 =signal, Pin 2 ECU ground, Pin 4 chassis ground?
    Colors seem to be: signal (thin, varies), brown-yellow (to valve cover), brown-green (chassis ground?), brown-yellow (+12V?).
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    This isn't a pin out but it does include everything you will need to know to rewire your ignition coils. The signal wires are the only ones unique to each cylinder. Clicky clickŪ
