Results 1 to 26 of 26
    Senior Member Two Rings seattlematt's Avatar
    Oct 10 2009
    1981 Fiat Spider, Sprinter, e46 vert
    2011 s4 vs 2012 A6
    Hey guys, I'm trying to decide between these two cars it seems that they both have the same engine similar drivetrain. I really like the luxury of the A6 and I love the 3.0t. What does the S4 offer that doesn't exist in the A6?
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Quote Originally Posted by seattlematt View Post
    Manual transmission.
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Overall the a6 has more options and features. The S4 has sport seats, manual transmission and carbon interior trim that wouldn’t be available on the A6.
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    DSG- which you can tune, less weight etc. Less tech in the S4 but it's a trade off I guess.
    2012 S4 (sold)
    Established Member Two Rings clAudi's Avatar
    Jul 17 2017
    Brooklyn
    While the S4 is definitely not compact it's noticably shorter than the A6 as well overall more agile.
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by clAudi View Post
    Agreed, and the S4 itself is already a bit of a porker.
    I had a 2012 A6 as a loaner back when I had my 2012 S4. I enjoyed the A6 for the weekend I had it. I was impressed by the fuel efficiency of the 3.0t in the A6...it was better than I was getting in my S4.....however, the A6 version runs a less aggressive tune than the S4 from the factory if I'm not mistaken. It is a large, lumbering car but it was comfortable. My wife and I had plenty of elbow space to share on the center console during our weekend road trip, and admittedly it felt a bit cramped when we got back in the S4. But for spirited/fun driving I would pick the S4 any day.
    SOLD 2015 Daytona Gray S4
    May 20 2010
    Really OP, it's what you are after. Also, stock, the A6 makes less hp and tq than the S4 (probably not going to be an issue if you don't keep it stock).
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Oct 10 2009
    In the A6 I would certainly go stage 1 or maybe 2, so the power difference might become negligible. Both are Auto, I have not seen manual S4's in the similar price range, whereas autos are showing up 17-20K which is about the same price as the 2012 A6.
    The a6 has 8 speed auto, the S4 has SMG?
    Oct 02 2005
    The Moon
    Just a couple points.
    The C7 A6 is only 150lbs heavier than a B8 S4. Same engine, lower tune, but when flashed it makes the same power. One caveat is the transmission only redlines to 6400rpm. Once a TCU tune comes out it will make the gap to tenth in the 1/4 vs a like for like tune vs S4.
    I'm running 11.46 and expect to be 11.1 once the tcu tune is released from APR.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by p3u View Post
    Was going to mention this. A6 has like ~30 or so less ponies from the factory.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Oct 10 2009
    Thanks everyone for your responses. It sounds like I am still going to stick with looking for c7 3.0t A6.
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    S4 will be a better drivers car from a physics standpoint... while the A6 will have backseat that an adult can sit in comfortably for more than 30 minutes.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by GandalfTheIbis View Post
    But it will feel sloppier, especially around curves.
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Pro's (IMO)
    S4 - True Dual clutch transmisson, Sports Diff, better seats for spirited driving, more agile, Flat bottom steering wheel, over all more sporty, "S" badge, more after market support
    A6 - Bigger space/more cargo, same engine as the S4, more mature look, more comfortable (unless lowering it), better interior noise reduction
    Con's
    S4 - More aggressive and younger styling, harsher ride, DSG maintenance
    A6 - "A" badge never will be an S or RS no matter how much you mod it, sloppy handling, Slush box transmission less crisp, not much of an eye catcher now days, even more dulled driving experience, no matter how much you mod it'll only be a freeway cruiser 1/4 mile muscle car
    I have a child with a rear facing baby seat and I have not had an issue with space with a stroller/bouncer/diaper bag/wife.
    I moved from a b7 RS4 and the interior space feels much bigger in a B8.
    I though about an sq5 but when I need all that space is probably 5% of the time. I didn't want to sacrifice 95% of fun for 5% of necessity of a bigger space.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    If it's your only car I would vote for a6. If you already have a people hauler S4 is more fun everyday, mostly due to the sport diff. You can carry much more speed into a turn and the car feels pretty neutral.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Oct 02 2005
    The Moon
    I went through the same thing, B8 vs C7. Ultimately I went C7 due to size, both physical room in the vehicle for a car seat and trunk space.
    Obviously it won't be as fun of a car in the corners, so I didn't purchase with the intent or expectation for it to be.
    Style wise is subjective, both are sharp looking vehicles, esp when tastefully modified.
    Power, near as makes no difference, esp when tuned.
    Established Member Two Rings nowakm99's Avatar
    Jan 21 2018
    2016 Audi S4, 2012 Cayman S, 2025 Integra Type S
    Toronto, Canada
    My personal philosophy is as follows: If you enjoy spirited driving, buy the smallest/lightest car that you can live with. If you need the extra space, go bigger with the A6.
    2016 S4: IE Stage I, IE CAI, AWE Touring Exhaust, CR-15, H&R Rear Sway bar w/ Moogs end-links, 034 Motorsport transmission mounts, Vorsteiner V-FF 103s in Machined Titanium
    Senior Member Two Rings juniorcruzer's Avatar
    Sep 28 2014
    2007 Suburban
    Center City Minnesota
    I own a 2010 A6 and 2010 S4....S4 is a bit more nimble and toss-able than the A6, but the A6 is a much better put together car. Don't get the rattles and creaks that I have in the S4. A6 is APR stage 2, and it will surprise the hell out of you how well it goes. I'm 6'1" and it is a much better experience getting in and out of the A6 than the S4, but the seats and adjust-ability on the S4 is better.
    Both are good cars for what they are intended. Just a matter of what you are looking for.
    Jon
    2010 S4 3.0T, chipwerks stage I
    2010 A6 3.0T, APR Stage 2+, Roc Euro Intake, VMR V710 18x9.5 HyperSilver, 30% tint, A3 clear marker lights, LED Reverse lights, RS6 Grill
    Apr 04 2017
    Chicago IL
    Quote Originally Posted by nowakm99 View Post
    This matches my experience as well. I drive my bigger, less flashy (by local standards) vehicle back and forth to work, and I long to be in my S4 instead almost every day. Next work car is gonna be a mini cooper S
    Feb 23 2016
    Chicago
    S4 is more agile. The A6 is too large. If there's a gap in traffic, you have to think twice before threading the needle.
    Apr 04 2017
    Chicago IL
    Lol, in general you should probably think twice about "threading the needle" in traffic.
    Oct 10 2009
    I get what you mean, 9 shouldn't make much of a difference in fitting between cars on the freeway :)
    Oct 02 2005
    The Moon
    It doesn't lol.
    Sep 28 2014
    2007 Suburban
    Technically 8.7"...I always round up as well.
    Jon
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    Sounds like the OP wants a comfortable cruiser more than an engaging driving experience. I think the A6 with the 3.0 is great for that. That car feels more than 150lbs heavier than the S4.
    Veteran Member Three Rings TEB's Avatar
    Sep 19 2010
    '70 Cutlass, Yukon, MDX, Pilot
    Ponte Vedra Beach, FL
    If you'd like the extra space and don't intend to track the car, the A6 is an easy decision. I've had a B5, B6, and now B8 and never felt bad stuffing adults in the back seat if they want me to drive.
    2011 S4 6MT Ibis White|Panda Nappa|Titanium|Carbon|NAV|Sport Diff|B&O|H&R Sports|Unitronic 2+|RS5 brakes|034 RSB/Insert|10mm Spacers|Tints
    (Gone)2004 S4 6MT Silver|Black|Carbon|Bilstein|Hawk|Magnaflow|ECS
    (Gone)1998 A4 5MT Black|Black|Bilstein|A8/S4 Brakes|APR Exhaust|AWE DTS|Intrax Extreme|Flik|GIAC|Etc
