This poll was created to consolidate information from recent threads about turbo failures. If YOU have experienced a turbo failure, please take the poll and post the year, model, mileage, when any of the items in the poll were completed and when your turbos failed, and if tuned.
I'm not able to add attachments for some reason, but here are the related TSBs.
21F2 service campaign - ECU software update and replacement of coolant lines and O-rings - campaign started mid 2017 and appear to be limited to pre-facelift 2013-2015 all 4.0T models.
TSB 2036167 - Coolant Pipe seepage on Turbocharger - only MY 2013 all 4.0T models, BUT the TSB i have is dated June 2015 so may not have included newer years. This TSB outlines replacing the coolant line O-rings and came out well before the 21F2 service campaign.
TSB 2044640 - Engine difficult to start, turbocharger damaged - MY 2013-2016 for all 4.0T models, TSB dated Nov 2017. This TSB covers replacing the failed turbos.
TSB 2034999 - Miscolored pipe on turbocharger - Since people have mentioned the driver side turbo being oily/dirty during swaps/failures. This TSB explains the condition is due to the crankcase breather only being connected to the driver side turbo (TSB shows it dirty/oil varnished, passenger side clean). TSB is informational only, no service required and considered normal.
On my car, I had the O-rings TSB completed then a few months later, the 21F2 service campaign was released and had that completed too, no turbo failure yet at 36K miles.
