Page 1 of 5 123 ... LastLast
Results 1 to 40 of 189
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    what springs are you using on your rs3 (mag ride)
    Looks like i will need to lower the car to have it sit properly with my wheels.
    what options are available that retain stock ride quality but lower the car about an inch or so
    and NO i dont want to pay a tax for the Mss kits that sell for much cheaper over seas
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Feb 01 2018
    Chicago
    Quote Originally Posted by saxon View Post
    MSS.
    Aug 18 2017
    Ontario Canada
    I bought my MSS kit directly from them. Is that not an option anymore?
    Oct 16 2012
    pa
    Quote Originally Posted by Thibs View Post
    not in the usa, redirected to xlr8 who "owns" the market and as such can charge whatever they want
    Nov 14 2014
    pnw
    Bummer, the springs are $1200?? I could have sworn they were half that previously.
    Established Member Two Rings Dubonfire's Avatar
    May 21 2014
    H&R Spring are great for the price. No rubbing 19x8.5 ET40 with 8mm spacer 4 corners
    Sent from my LG-H915 using Tapatalk
    MK7R Sold
    2018 Audi RS3 IMS 710H Sold
    2022 S3 8Y Project: FBO Racingline Stage 2, tons of Racingline & Superpro suspension/handing mods
    Oct 16 2012
    pa
    Quote Originally Posted by Dubonfire View Post
    what size and brand of tire?
    May 21 2014
    Oem Pirelli Square 235 35 19
    from my experience, Continental will look the same and Michelin tend to be wider.
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Seemed the consensus on the FB group was the H&R's are very stiff, how do you think the ride is on them?
    May 21 2014
    They are OK, i always run the car in dynamic mode unless the road is crappy. I have been running the setup for only 4 days but the comfort mode equal something between normal or dynamic. Next step for me will be a sway bar kit.
    MK7R Sold
    Aug 01 2017
    Cali
    That looks . We have similar taste.
    I had a chance to ride my buddy’s RS3 with H&R (less than 300 miles since install) vs mine with MSS (3000 miles since install). Ride on MSS is definitely better but H&R was tolerable (ymmv).
    As far as cost is worth the difference, that is very subjective. I would say for the ride characteristics and comfort, MSS is worth the price but that might be different for other people.
    Senior Member Two Rings jwil's Avatar
    Sep 03 2017
    2018 Audi RS3; 2018 Audi SQ5
    Quote Originally Posted by ahyeah View Post
    The are ridiculously priced. Hopefully another distributor pops up soon.
    Senior Member Two Rings seanix9's Avatar
    May 24 2017
    Melbourne - Australia
    Quote Originally Posted by jwil View Post
    kW just did.
    Similar concept with height adjustable springs and cheaper than MSS.
    Although MSS uses Eibach springs who are the leaders in this field.
    2016 RS3 SB. 2015 A4. 2018 RS3 Sedan
    Current: 2018 Ara Blue RS3 Sedan
    Past: 2016 Glacier White RS3 SB
    Instagram: Melbourne_rs3
    Sep 03 2017
    Quote Originally Posted by seanix9 View Post
    kW just did.
    Link?
    There’s nothing on their product pages about that.
    Established Member Two Rings davebeats's Avatar
    May 01 2017
    2018 Audi RS3
    Tampa FL
    I'm using H+R, feels stock to me
    Oct 22 2013
    Bicycles
    United States
    APR
    Veteran Member Three Rings FuzzyHat's Avatar
    May 21 2010
    Chicago, Illinois
    Quote Originally Posted by ScottyT555 View Post
    MSS.
    Scotty, do you have MSS? I want to get a real world comparison before deciding on which I want to go with. Right now its up to H&R and MSS, but MSS is like $1000+ more. So want to make sure.
    2018 RS3 - Unitronic ECU - Unitronic TCU
    Feb 01 2018
    Chicago
    Quote Originally Posted by FuzzyHat View Post
    I have them ordered so should have them within a couple weeks. As soon as I do we can meet up and go for a ride. The main reason I went with MSS (other than the extremely positive feedback from everyone that has them) is the height adjustability. Since I’m going with 20” wheels I wanted to make sure I could really dial it in and go as low as possible without rubbing.
    Established Member Two Rings meticulist's Avatar
    Jul 13 2017
    Phoenix, AZ
    Link?
    http://blog-int.kwautomotive.net/kw-...l-audi-rs3-8v/
    '17 RS 3 | @meticulist
    Feb 16 2004
    Bay Area
    kW just did.
    Not trying to push the MSS Kit, but the KW kit although similar is very different from the MSS Kit design. The KW kit uses a helper spring in the rear to keep the main spring seated. It has no bearing on spring rate. The KW kit is essentially an adjustable height basic lowering kit.
    The MSS Kit uses a progressive tender rear spring in addition to the linear rate rear spring. This means that the rear actually has 3 spring rates. The first spring rate is completely collapsed and only activates when the rear drops into a pothole. The secondary rate is the rate that the car typically drives on and is "softer," easier for daily driver. The third rate comes in to play when the car rolls enough and collapses the secondary rate, the final rate now takes over and gives the car added rotation/weight handling capability. The progressive tender is not a cheap spring. KW likely sees massive economies of scale, but something to keep in mind.
    Out of curiosity, what do you all think is a reasonable price for this? The adjusters are not cheap, nor is all the additional springs and couplers, that all adds to the price. What kind of ride height range is acceptable? Keep in mind, going too low is going to bottom the shock and will ride poorly regardless of who makes the kit.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    Oct 02 2017
    Not trying to start an argument but using dual springs off of a coilover set up hasn't really been proven to do anything better than a progressive spring. Here is a really good read on dual springs and how to use them http://shocktherapyst.com/the-truth-...-rate-springs/
    Basically without a way to stop travel on the softer spring you end up somewhere in the middle on rate and compression. I have stated I would love to have a video of the MSS set up to see how these springs are actually reacting under load.
    Jan 26 2018
    Huntington Beach, CA
    Do these springs also work for us RS3s with dynamic plus?
    Feb 01 2018
    Chicago
    Quote Originally Posted by uclaman View Post
    They absolutely do. Malaka (George) has them on his RS3 with D+ and loves them.
    Jan 26 2018
    What is the difference between all the MSS kits? Theres sport packs and track packs? Maybe I just missed the explanations on the website?
    Oct 16 2012
    pa
    from my understanding, the track pack just gives adjustable height in the front as well
    Feb 01 2018
    Chicago
    Not entirely accurate. Sport and track are very similar and both allow for height adjustment but the track front springs allow for an additional 10mm of ride height adjustment. There’s definitely more explanation on the website.
    Jan 26 2018
    Nm. Found it.
    Jan 26 2018
    But then what is the 'LS track pack vs regular track pack?!
    Jul 25 2010
    WI/IL
    LS is stiffer than the track pack.
    Feb 16 2004
    Bay Area
    Quote Originally Posted by OE2 View Post
    A multi spring arrangement is very similar to a progressive spring, but has one main difference. In a progressive spring the rate has more of a bell curve. The rate tends to amplify pretty quickly. As a user you are not able to tune when the next spring rate comes into play. In a stacked arrangement the user can tune when the rate transitions via the use of different main springs, or more forcibly through a crossover ring to stop spring travel. In the case of the MSS kit, the progressive tender does in fact coilbind and place you into the main spring. It doesn't take much additional load, the tender is nearly at coilbind at static. Using a progressive tender means the rear has a third rate which is helpful for providing an even softer rate for pothole additional absorbtion. The stacked arrangement provides for a linear rate as you move through the spring travel. It has less of a smooth/sharp rate, and more of a straightened path as you coilbind. Tuned correctly this can give a more pleasant ride quality as it ramps up.
    The main benefit is really on bumpier circuits, where the car can ride on a softer rate and maintain composure before moving into the main rate to control body motion. Think Sebring International, super bumpy circuit where you need both compliance and control. Unfortunately the MSS Kit doesn't employ this same stacked arrangement on the axle doing the steering, ie the front. This would have amplified grip.
    If you already have Dynamic Plus, it would be much easier to switch to a complete coilover kit. The MSS Kit option provides for great spring balance, but does not give you a shortened shock to cope with being lower. Nothing worse than getting into a corner and hitting the stops.
    Jan 26 2018
    Quote Originally Posted by rex_racer View Post
    Ah That makes sense.
    Which coilover setups are currently available for the RS3?
    Oct 02 2017
    I know how it works, my question is does the MSS kit with the divorced set up actually do something more than a well thought out progressive spring in the rear. In the link i shared the best way to run dual springs is to actually have them on the strut and have a form of travel stopper for the 1st spring to then bring in the spring rate of the second. I do not know how the lack of that functionality impacts the rear. I have used the link i shared above to discuss with both ground control and hyperco and both can't initially understand what benefit it's providing.
    this is why i say I would love to see a video of the rear suspension in action I would like to understand how MSS is working this out. Of course it doesn't help they refuse to share their spring rates.
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    Why not MSS?
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Well I guess cost. Most spring sets are usually only couple hundred dollars.
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Sep 01 2012
    Edmonton
    Personally i would go with MSS and pay a lil bit. KW HAS kit is not in the same league as MSS, but that my personal opinion.
    2018 RS3 Panther Black
    Nov 25 2011
    Just went through this debate with myself. I went with the MSS kit. Getting it installed on Saturday I cant wait! The way I see it is these are double the cost of springs but half the cost of coilovers for this platform and allow me to retain my adjustable suspension while getting the benefit of dialing in my own height settings.
    2018 RS3 & 2017 SQ5
    Insta: @ccampbs
    2012 A4
    2015 S4
    2014 SQ5
    Nov 10 2017
    California
    I'm getting abt tomorrow.
    Sep 01 2012
    Edmonton
    Quote Originally Posted by weepingwillow View Post
    Interesting where are you picking these up at? I haven't heard much from ABT, but they are big across the pond.
    Nov 10 2017
    California
    Quote Originally Posted by WAF View Post
    Paul@Supremepower ordered them
    Sep 01 2012
    Edmonton
    Thanks, hopefully you can give some insight on them once you've have them on.
