I would like to sell: AUDI S6 C5 Instruments cluster (USA, miles!!!) with COLORMFA display installed (A6, RS6, Allroad).
ColorMFA dispay looks greate and gives you extremely wide opportunities to select the parameters to see and not only this. You could check and erase faults, see the groups as you use VAG-COM, make graphs, but you do not need any cables and laptops.
100% original look with matt surface of the display. English, Russian German etc. languages, software update. More information you could find just google the "ColorMFA".
Your car should be 2001...2005 year, (with motor CAN bus). Petrol or diesel, automatic or manual gear box, it does not matter. Login code will be provided and I could make the millage you need. On video it was installed on Allroad 2.7t 2003. I could send it with original A6, S6 or Allroad eeprom. To see the boost display you should connect one extra wire from boost pressure gauge to the instruments (in diagnostic mode "vag-com" mode it could be seen without it).
Ways of installation to your car (immo 3 only):
1. I could change the dump of the cluster and it will have status "New". Then you install it and adopt to your keys and immo using Vag-Com cable or VCDS. You need your original cluster Login Code. (using VAG EEPROM Programmer for example and KKL or VAG-K+CAN Commander 1.4 or Galletto 1260 cable, just search at ebay)
2. Reccomended!!! You managed to read the dump of you cluster (the same cables and soft). Then you send it to me (by email or giving the link to download it from fileserver) and I modify the dump and write it to the cluster. In result the cluster will have all your keys adopted, your milage, your radio code etc. and the speed will be shown correclty and even your diesel tacho (if you have diesel) will display correct rpm . It will work 100% The cable costs just 4-5$ at ebay.
3. You could apply to a specialist in your region to do all this thing.
Do not hesitate to ask any question you have.
More photo and video but with S6 Europe km/h cluster are in this ebay lot:
Posts about this display at audizine you could read
here
and here
I would like 649$ shipped.
I'm not in the USA so please be informed that the shipping with tracking could take up to month (by EMS or USPS).
Paypal payment only.
