It seems that OP posted and left. Never replied further or told us what he did. Hummm.
My two bits, and that is all it is - - - it is possible to do too much with the whine if one is not careful. I agree that open filter element and metal tube will produce the most audible whine. But, that may not be the best choice for maximizing power and it can wear thin over time.
The single most important factor in being able to hear the supercharger is replacing the stock throttle body to filter tube with anything else. The stock tube has a built in resonator chamber that cancels out all or most of the sound. Any replacement tube that does not have that chamber will let you hear the whine.
Reinforced silicone does have the advantage of being both stiff, resisting collapse under maximum boost draw, and having some insulation effect from heat transfer from the hot engine compartment. Metal tubes will get hot quickly and have an effect (perhaps subtle but still present) on the temperature of the air entering the throttle body.
That is also the case with true open element filters if they are not isolated from the engine and exhaust manifold on the passenger side. Hot air has fewer oxygen molecules which means less power at the same AFR. You want to keep the intake charge as cool as possible and that begins with ambient air. That's why our cars are much slower in the heat of the summer than in cooler air in winter, spring or fall.
The stock airbox can be opened on the side facing the passenger side headlight. That will also increase supercharger whine while drawing air from an area much cooler than on the exhaust manifold side or general engine compartment. That is what I did. There is a circular molded area on that side of the stock air box. It is easy to open using an appropriately sized hole saw attached to a cordless drill. Obviously, the larger the hole, the more airflow and the more supercharger while. I'm satisfied with matching the size of the circular molding.
Higher flow aftermarket filters will also increase air flow and intake noise, including whine, if that is what you are looking for. I began with the K&N 1987, but have recently changed to the aFe Pro 5R, which probably has the highest safe flow rate (adequate filtration). It is a dual cone design that also draws air from the end, directly in front of the hole cut with the hole saw.
The combo seems adequately loud to me and probably maximizes air flow without raising air temperature entering the throttle body.
