Perhaps you came across some of my commentary regarding my H&R Street Performance coilovers. I also tossed around the idea of adding spacers to the rear springs because with the rear mounts spun all the way up, meaning the top end of the collar is even with the top end of the perch (no threads overhanging), this is my ride height. Meanwhile, the front spring perches are somewhere in the middle of the length of available threads on the dampers:
And for whatever reason, maybe a departure from this discussion, both of the front springs look like this when the weight of the car is on the wheels at the above pictured ride height:
I count 1, maybe 1.5, active coils with the rest of them dead stacked. Sure enough, the ride on this setup is fairly harsh in my opinion. It's noticeable more jarring than the ride in my old 350z which was lowered on BC BR Series coilovers, i.e. "Chinese junk" by this forum's standards, to this ride height (any excuse to whore a pic):
The Z had a nice solid "thud" when hitting bumps, whereas the S4 has a nice calamitous "crash". So I am also in the market for a new setup and have considered the B12 kit but I'm afraid I won't be satisfied with the look after having my ride height as it is currently. Meanwhile, my current ride height gripe is that the rear appears to "sag" a bit relative to the front, which gives me just a bit of that reverse rake look, but because I'm at the top of the rear adjustment threads I can't raise the back end any higher without starting to hang some of the collar threads off the top end of the perch. I've never gotten a clear answer as to whether it's acceptable to do that, and if so by how much, because ultimately all of the force of the spring is being transmitted through those threads.
