Page 1 of 3 123 LastLast
Results 1 to 40 of 97
    Mar 25 2018
    Random Misfire during idle and ignition
    I have a 2009 Audi A4 2.0t that is plagued with a random misfire code. The car mainly misfires when it is idling, or during ignition. I have already put in new ignition coils, coil connectors, high pressure fuel pump, alternator, pcv valve and spark plugs. I have also done carbon cleaning. The car is stock and has no modifications.
    Does anyone have any thoughts or ideas as to why the car is still misfiring?
    Deactivated Two Rings
    Mar 25 2015
    '68 Nova, Subaru Forester
    United States
    Do you see any oil leaking in between the engine and transmission?
    Sent from my SM-G955U using Audizine mobile app
    Dec 03 2016
    nowhere
    The 2.0T will misfire at cold start to begin with. Carbon cleaning rules out that unless it was like 30K miles ago.
    Misfires are as fundamentally simple as air, fuel and spark as they say, but these can go outta wack for a plethora of reasons. You or someone with vagcom has to do some serious logging. I could tell you to something like "do a compression test" and that would just be a start in only one of many directions.
    HEAR
    APR stage 2
    Mar 25 2018
    Sometimes I do see some oil leaking, yes.
    Established Member Two Rings TJet1.8's Avatar
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    I had the same type of issues with my A4 (2011) and the wife's A4 (2012).
    As mentioned above, there could be a plethora of reasons for the misfires.
    What seemed to work (for me) were to replace the following:
    1.) Coilpacks
    2.) Sparkplugs
    3.) MAF
    The wife's A4 (78,000Km's) smoothed right out after replacing the above.
    My A4 (97,000Km's) got better...but wasn't quite perfect.
    Now...I had the Stage 2 Piston/Rings replaced on my A4 under warranty AS WELL AS a new Timing Chain/Tensioner/Guides at the same time.
    Once that was done...it was like a new car off the lot. She was smooth as butter.
    GL.
    • 2017 A4 2.0T - Custom Stg2 ECU & Stg1 TCU Tune (409HP/395TQ - No Meth) from garageautosports.com (thanks Bill!!), CTS CAI + TIP, CTS Intercooler, CTS Charge Pipes, GFB DV+, CTS 3" Test Pipe, CTS 3" Catback, APR Coilpacks, RS3 Plugs, 034Motorsports Trans Mount Insert, Snow Stg2 Water/Meth., Bilstein B8 Performance, H&R Sport.
      2016 Q5 3.0T - Custom Stg1+ Tune (455HP/395TQ) from garageautosports.com (thanks Bill!!!), CTS Supercharger Pulley, 034 Intake Pipe, aFe Dry Filter.
    Mar 25 2018
    I had my mechanic look at it today and he said that all the spark plugs were loose and that could be the reason for the random misfire. We removed them and put them back correctly and the misfire persisted. I went back to the shop for further diagnosis; my mechanic scanned the car live and found that cylinders 1 and 3 were the only ones misfiring. We swapped the spark plugs to cylinders 2 and 4 to try and determine if the spark plugs are the problem. My fear is that the timing chain has skipped a couple teeth. Anybody have any further thoughts?
    Mar 25 2018
    Any thoughts?
    Dec 03 2016
    nowhere
    So the misfires stayed on 1&3 after you swapped the plugs, yes?
    You swapped the old with new VW/Audi coil packs, yes?
    How long ago was the carbon clean?
    Don't know your mec's prowess, but he should've been able to tell if there was a timing issue if he had a capable scanner.
    Some things I'd do is look at the injection IQ, injection quantity or injection quotient depend on who you talk to. I'd to this just to get a clue on how the injectors are doing. Ever try a couple of cycles of fuel system cleaner?
    Mentioned a compression check, this could easily be done. I doubt this would be the issue though unless your engine had bad history or you like to beat on it.
    I'd check fuel pressures, both the high and low sides.
    I'd even borescope at least one of the intakes ports.
    Honestly, you'd be better to find a really experienced independent Audi mechanic and get his opinion after his diagnostic.
    Could be something really obscure and simple. But without taking some in-depth looking it's really hard to pin without more info. Get that oil leak looked at too.
    So you just have the misfire codes?
    HEAR
    APR stage 2
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    Oh...forgot 1 thing...
    I also ran 2 tanks of gas with fuel injector cleaner.
    Then...took them on the highway for an Italian Tune up
    (Hey...I'm Italian, eh oh...oh eh...)
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    Try reducing the spark plug gap and/or running an NGK 8 heat range plug (or equivalent) and let us know how that goes. It may also be time to upgrade to a set of R8 coil packs.
    Sent from my SM-G930VL using Audizine mobile app
    "Big" Mods:
    -APR turboback exhaust w/ gutted HFC
    -Intake
    -Treadstone TR8 intercooler
    -2014 A5 engine to fix the oil issue (REEEEEE)
    -Eurodyne Stage 2 tune (I did it myself. Fingers crossed.)
    Garage:
    2011 Audi A5 2.0T 6 MT
    1978 Dodge W-150 (318 cu. in. V8 w/ 4x4)
    2015 VW GTI SE two door DSG (Wife's)
    Mar 25 2018
    Quote Originally Posted by flowhigh View Post
    YEs, the misfire stayed on 1 and 3 even after swapping the spark plugs. I did carbon cleaning less than 5k ago. We discussed doing a compression test but he ruled it out because the car drives fine. I've tried tonnes of bottles of fuel cleaner, nothing has worked. At this point I do believe that it is ignition related, as the check engine light comes on very shortly after I turn the car on, or when i am idling. We even replaced the PCV valve last week to try and fix the issue (because there was a pin hole leak in it), and we were both shocked that the misfire has persisted.
    Basically, the misfire only occurs during idling and ignition. I have ordered a set of NGK spark plugs from amazon. We'll see how that goes.
    Mar 25 2018
    Bump
    Feb 24 2004
    Minneapolis
    Hate to say it, but lots of guessing here and it's getting expensive. You need to get codes, preferably VCDS. If your timing chain jumped a tooth, you'd see codes. And probably have a CEL. Might also be intake air leak, and sometimes that won't even show in a code. I suspect that's why someone asked you about oil leaking out the back of the motor. I've seen air leaks in a bad rear main seal. But you need more info at this point. We're all just spit-balling.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Dec 03 2016
    nowhere
    Quote Originally Posted by adamleaf8601 View Post
    You've also swapped the ignition coils around?
    The B8's had issues with the control runner getting stuck, but you only have the issue in 1&3 so that might be ruled out. I'd definitely take a close look at the injectors, some B8's had injector seal issues. Any smell of fuel? If your mec is good with an oscilloscope he'd be able to tell if they're functioning correctly otherwise try to get to a hold of a ross-tech cable and take a look at measuring block 015 at start-up and idle.
    HEAR
    APR stage 2
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    How is your oil consumption? Your symptoms are very similar to what I experienced before having Fix1 & 2 of the oil consumption issue on my '09 A4. Turbo wastegate may also be a possibility with this one. Scan for codes. How is your oil consumption?
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Mar 25 2018
    Quote Originally Posted by Crucible35 View Post
    My oil consumption is fine that was fixed years ago. What is turbo wastegate?
    Dec 03 2016
    nowhere
    It is small metal flap situated inside the exhaust side of the turbo controlled by way of the wastegate actuator. This small flap either allows or restricts the exhaust circulation and it's pivotal in the creation of your boost.
    HEAR
    APR stage 2
    Mar 25 2018
    Thankfully Audi was able to diagnose it today and updated the ECU. No more misfire after the update and throughout my whole day of driving.
    Feb 02 2016
    How much did audi charge u for the update?
    Mar 25 2018
    One hours labour
    Feb 02 2016
    One hours labour
    Not bad and congrats on resolving it.
    Senior Member Two Rings Tyintegra's Avatar
    Sep 13 2010
    2013 A4, 2013 Golf R
    Bothell, WA
    What do you mean by "update the ECU"? Is there a TSB for this?
    Dec 03 2016
    nowhere
    Did they give you a reason the update was necessary and what did the update consist of that resolved the misfires? Sounds like they might've just reflashed.
    HEAR
    APR stage 2
    Mar 25 2018
    I’m not entirely sure, but they did say they updated it. They said they watched the cylinders live and confirmed the misfires were occurring on 1 & 3. They stated that after they updated it though, there were no more misfires after the car ran for an hour. Perhaps it was a reflash; I’m not entirely sure but I’m just relieved it’s fixed. It was extremely annoying having the cel come on and flash randomly. Kudos to Pfaff Audi for their honesty and professionalism.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    They let it idle for an HOUR?!? Can you post a pic of the work order they gave you?
    2011 A4 Avant Prestige S-Line
    Mar 25 2018
    Quote Originally Posted by Novarider View Post
    They let it idle for an hour in order to be certain that the misfire was gone in cylinder 1 and 3 after the ECM update. That is pretty much all the work order says and that they want me to monitor it if the CEL light comes back on, they may have to replace the injectors.
    Jun 14 2015
    2016 Q5 3.0T
    Ontario, Canada
    Hmm...I must say this is the first time I've heard of a software update fixing a rough idle issue.
    My 2011 and the wife's 2012 never had any update applied (that I know of).
    The Guys at Pfaff are pretty good though, they have their own Tuning shop (Pfaff Tuning) and Motorsport division...so they are generally cool with minor mods.
    Which location did you go to? Woodbridge or Newmarket?
    Mar 25 2018
    I was surprised too. It's been a couple of days and the misfire hasn't returned. I guess it also helps that I have remedied most of the other causes of the misfire in the past while. Pfaff tuning is not on site and I do not believe Pfaff Audi directly affiliates with them. I went to the Woodbridge location, I do not like the Newmarket location.
    Dec 03 2016
    nowhere
    Quote Originally Posted by TJet1.8 View Post
    It still hasn't been concluded that an actual software update was flashed.
    HEAR
    APR stage 2
    Apr 22 2010
    This sounds really strange to me. Did they give you any codes when they scanned the vehicle? Given they told you to keep an eye on the CEL.....they know it's coming back and they didn't actually fix the issue.
    Mar 25 2018
    Random Misfire, Cylinder 1 and 3 Misfire.
    Jul 02 2017
    Knoxville TN
    So it came back?
    Mar 25 2018
    So it came back?
    No it didn't. I was answering the question about when they scanned the vehice before updating it.
    Mar 25 2018
    Something strange happened yesterday. I ordered Carista to enable a few features and for some reason the misfires came back immediately after turning on the features I want. Anyone have any thoughts?
    Feb 24 2004
    Minneapolis
    That might explain how/why a flash solved things. If I were you, I'd undo all your just did. If that fixes it again, then add your changes in one by one till you know what's screwing things up for you.
    Mar 25 2018
    Problem is I changed several things I don't remember everything lol.
    Mar 25 2018
    Quote Originally Posted by mtroxel View Post
    Do you think these changed could void my warranty?
    Mar 25 2018
    I removed most (from what I can remember) of the carista modifications and tested the car. The misfire didn't return (fingers crossed).
    Jul 02 2017
    Knoxville TN
    What had you installed that you removed?
    Mar 25 2018
    Mainly like window functions and lighting functions.
