Results 1 to 6 of 6
    Active Member One Ring JoshPershad's Avatar
    Mar 12 2018
    Toronto, ON
    Looking for a good B7 A4 2.0T Fuel injector DIY
    Anyone got any good links?
    Sent from my SM-N920W8 using Audizine mobile app
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    http://www.stasisengineering.com/sit...ongitudial.pdf
    You’re welcome. Or can I just install them for you?
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Aug 04 2015
    Kansas City
    The guide that james12lucy posted above is top notch. Fuel injector section starts on page 28. Many of the bolts are different sizes so consider making an organizer for each step like the one shown here. It will make it easy when it comes time to put everything back together.
    Senior Member Two Rings aviator79's Avatar
    Apr 10 2012
    Suffield, CT
    Bumping thread as I have to swap injectors to a new head.
    First,
    Do you all ever send injectors out for cleaning?
    I normally would on other DI engines.
    2nd
    Do you normally replace seals/orings?
    On other DI the bottom head to injectors seal must be replaced. These injectors are different but assume that seal also needs to be replaced?
    Anyone have pn? I can probably look up as think it is one of these:
    Fuel Injector Retaining Clip 35906037
    Fuel Injector O-Ring 035906149A
    Injector O-Ring Kit 06D998907
    Fuel Injector O-Ring 06F906036A
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    May 05 2014
    B6 A4, B7 A4 and B8 A5 all R Black
    Adelaide Australia
    You can by the injector seals and retainers as a kit rather than as separate parts from Europaparts or ECS
    Apr 19 2019
    milwaukee
    i had spoken to this place -- http://www.mrinjector.us/price-list.html -- about having my injectors cleaned. Ended up not sending them out but his price seemed fair and offered to replace the seals as part of the service, but if you google gdi injector cleaning there are more.
    You could try sourcing each component individually but otherwise for ease I would suggest an injector repair kit with all the seals and compression collar (audi/vw part number 06D 998 907). Ecs or other sites would likely have the best deal tho i ended up sourcing them thru a local vw dealer.
    The top is fairly basic with a small spacer collar and oring, but the white combustion seal at the injector tip requires some special steps. There are several videos on youtube showing the process.
