Results 1 to 4 of 4
    Oct 14 2013
    Waipahu, HI
    2018 Audi Q3 Oil Change
    Purchased the vehicle for my wife this year and in need of an oil change. Looks easy and all the filter is located on top of engine. I've seen the "suck method" to remove the oil but an old fashioned kinda guy and would like to drain the oil traditional style from the drain plug. Aside from replacing the crushed washer, anybody else have any advice on tools/method for replacing oil on the Q3?
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by AUDI_A4_2008 View Post
    I believe the engine for the Q3 is similar to the VW Tiguan so you could try that avenue - forums, youtube, etc.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    It is easier to use an extractor and suck it out the dipstick. It gets 99% as much out as pulling the drain plug. This is how all the VW/Audi/Porsche dealerships do it. It does take about 10 or 15 minutes for the extractor to remove all the oil. I use the Mityvac extractor.
    To pull the drain plug, you need to pull the black plastic bellypan off first, which is about 10 or 12 fasteners. If you don't have a lift, removing and re-installing the bellypan is a pain, due to the limited working room with car-ramps. You need to use a new crush washer, make sure you get the aluminum version, not the copper version. Check for leaks after refill, after a few minutes. These drain plugs and crush washers are finicky (another reason to use the extractor).
    When you remove the filter, loosen it about 5 turns, and let it sit for about 5 minutes to allow the oil to drain out. (When it is loosened a few turn, a drain port opens and allows the oil to drain into the oilpan.) Then you can remove it without making a mess.
    Refill takes 4.8 to 4.9 quarts. Always use an oil that meets the VW/Audi spec called out in your owners manual. Most commonly available oils do NOT meet this spec. I use Mobil-1 0W-40 "European Formula", easily found at Walmart in 5 qt jugs. Walmart also carries Castrol Edge (5W-40 I think), one version which also meets the VW spec, read the bottle. Always use genuine VW/Audi oil filters, or the same ones sold under the OEM manufacturer, made by Mahle or Mann.
    I suggest changing your oil and filter every 5000 miles max. Change the automatic transmission fluid and filter, and the rear diff gear oil, and the Haldex fluid & filter every 40,000 miles.
    The first gen (PQ35) VW Tiguan forums are full of usefull info. The Q3 and the Gen-1 Tiguan share the same exact engine, transmission, rear diff/Haldex all-wheel-drive system, steering and suspension (other than shock and spring rates, and the Q3 has aluminum front control arms, the Tigs are steel). The unibody chassis are similar, but the Q3 has structural enhancements which improved its small-offset crash test performance. The Q3 also has an aluminum hood and rear tailgate, the Tig is all steel.
    Feb 27 2013
    Twin turbo 350Z, Mercedes ML350, Audi Q3 and BMW 535i M sport
    New York
    Here you go just did it on a 2015 Q3.
    https://youtu.be/I8XjoVaJ-BU
    B7 A4, 6MT, Quattro - Sliver (Sold)
    JHM HPFP upgrade, JHM Test Pipe, JHM Y pipe, B7 S4 exhaust, JHM flywheel and RS4 clutch, GFB DV+, P3 boost gauge, S4 front & Rear brake upgrade, 034 rear sway bar, ST Coilovers, K&N filter, ECS Oil catch can, JHM K04-R Turbo Kit.
    Audi Q3 8U-White
    https://www.youtube.com/channel/UCWU...e_polymer=true
