Results 1 to 13 of 13
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    MK2 High-Res RNS-E Navigation Plus
    The unit in the original post has sold, but I have one more MK2 RNS-E available- details/photos in post #12.
    Hi, all! I have a MK2 RNS-E available. The mkII version of the RNS-E has several improvements over the original, including a high-res LED display, faster processor, traffic monitoring, piano black screen trim, aluminum knobs, etc...
    This RNS-E is in excellent used condition and includes the maps DVD and radio unlock code. As it has an A3 faceplate, this would likely be ideal for someone who already has a mk1 unit and can simply swap the faceplates.
    $680 shipped. Thanks!
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Junior Member One Ring
    Mar 16 2018
    Bucks County PA
    Sorry if this is a dumb question but will this fit on a b6 s4 without needing any adjustments?
    Junior Member Two Rings Oltean's Avatar
    Apr 01 2016
    B7 RS4
    Ontario, Canada
    Quote Originally Posted by rich4life611 View Post
    At bare minimum you'll need the faceplate for the b6.
    Depending on your existing headunit, you may also need an adapter harness, fakra antenna adapter, and a GPS antenna.
    Sent from my SM-G955W using Tapatalk
    Mar 16 2018
    Bucks County PA
    Quote Originally Posted by Oltean View Post
    Thank you! I literally haven’t seen the car yet but my buddy was at work when it got delivered and said it had navigation but instead of it being like the unit for sale here, it is one that pops up on the cluster
    Apr 01 2016
    B7 RS4
    Ontario, Canada
    You'll find out what it is when you get the car, but you can also turn on the turn by turn navigation in the cluster with the rns-e (unit being sold by OP), just takes some Vagcom shenanigans.
    Anyway I'm going to stop interrupting in this sale thread, glws OP.
    Dec 10 2011
    CLT | MKE
    As noted by Oltean (thanks!), a B6/B7 faceplate is needed for a proper fit. Besides that, it's quite straight forward. Direct plug and play if your car already has mk1 RNS-E. If not, just need an adapter harness and FAKRA GPS antenna which together run about $40.
    -Hayden
    Mar 16 2018
    Bucks County PA
    Thank you! Will definitely be in contact soon! Sorry for hijacking the post
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    is this still for sale? if so, MINE!
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Dec 10 2011
    CLT | MKE
    Quote Originally Posted by jonan View Post
    Sure is!
    -Hayden
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by LINDW4LL View Post
    Sure is!
    PM'd you for your PP addy.
    B6 Mods:
    RS4 Mods (sprint):
    Nov 25 2006
    Austin, TX
    payment sent
    B6 Mods:
    RS4 Mods (sprint):
    Dec 10 2011
    CLT | MKE
    Unit one is SOLD to jonan.
    I have one more MK2 unit available, which I'll list here for the sake of convenience. This one is also minty, with no scratches, chips, etc... The only flaw is a tiny mark/indentation on the bottom edge of the A3 faceplate; though hardly noticeable. This one, too, includes the security code and maps DVD.
    $670 shipped.
    -Hayden
    Dec 10 2011
    CLT | MKE
    Bump, $650 shipped!
    -Hayden
