Hey everyone, I decided to write up a quick guide on how to code and retrofit B8.5 sedan LED taillights into a halogen equipped car.
This swap is straightforward but is a bit labor intensive since soldering or crimping is required.
The major issue with this swap is that our stock halogen wires are significantly thicker than the LED harness, therefore the pins on the inner taillights cannot be transferred directly into the LED connectors. There are ways around this of course, however the route I chose left the stock wires and pins uncut and unmodified since I like having the option to switch back to halogens.
Another obstacle is the lack of sidemarker wire. Since the outboard LED’s have 5 wires going to them while the stock halogens only have 4. It is possible to lay a wire from the BCM to the sidemarker, it is far more work than I am prepared to do. For anyone adventurous enough I have included the proper coding.
First off, part numbers!
Unless you managed to purchase the taillights with the connectors and pigtails, you will have to buy them separately.
The outboard connector part number is: 4H0 973 713
The inboard (trunk) connector part number is: 8K0 973 754
Wires are not needed for the outboard connectors since the stock pins slip right in.
Inboard are more difficult. I ended up using the stock connector, taking the pigtails from the LED lights and using spade connectors and inserted them into the stock connector. This isn’t a perfect solution however for me it’s adequate, as long as you use proper insulation to prevent a short. The spade connectors that I used have part number 000 979 134 however any narrow spade connector with a width of around 3 mm will work too. You could directly splice the proper connectors onto the stock harness wires, however I did not want to undertake this. I do not have the part numbers for the LED connector pins.
Coding is very simple:
Open VCDS
46-Comfort System
Enter login 16017
Adaptation
Then change every value to what is in the chart.
https://imgur.com/vTiKGhl
PLEASE back up your stock coding! Don’t hold me responsible for entering the wrong value and forgetting the original. I’m just a dude on the internet trying to help any adventurous swappers out and will not take responsibility for any screw ups!
The chart lists channel 201 and 202 as the sidemarkers. For those ambitious enough to haul wires from the connectors to the BCM, use the values included. If not, leave them at the default zero.
I will post the proper pin and wire numbers in the next day or two, still need to take pictures and write down exactly what I did. Generally speaking the pins (except ground of course) can be placed arbitrarily in the connectors, since coding takes care of their function. However tracking down the corresponding channels is a PITA so just follow my wiring!
If anyone has any problems or needs advice feel free to ask!
