Results 1 to 31 of 31
    Aug 24 2016
    Sea
    B5 wont start wont connect to Vag Com or generic OBD scanner
    Never had an issue starting the car but recently had to replace the cam chain tensioner on my 1.8t B5 manual. Timed it and fired it up first try.
    Came back to it the next morning and now it wont start. Also, wont connect to Vag or an OBD.
    I've swapped relays, purchased a replacement ECU, checked all the fuses, checked and charged battery....after doing some research I see it could be the ABS module or possibly the K wire.
    Just wanted to see if there was anyone who has come across this issue or had any other advice. Would prefer to narrow down the guessing game if possible.
    Thanks in advance!
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    ABS module shouldn't stop the car from starting.
    What happens when you turn the key? Does it even crank or is it a completely dead "click"?
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Does it have the appearance of a completely dead battery? My first thought is bad ground or some type of open in the power wires
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
    Aug 24 2016
    Sea
    It cranks and sounds like it wants to start. Battery tested fine but I charged it up anyway. Cranks and cranks.....
    Want to say its not getting fuel but the pump is priming, Ive swapped out the fuel pump relay, swapped ECU, swapped crankshaft sensor....Ive checked all the fuses.
    I dont think the ABS module would stop the car from starting. I did read that it could be a reason why I cant scan the car.
    Already thrown a few easy possible easy fixes out there and have a few other ideas. Just curious if anyone has come across this issue or had any ideas.
    May 08 2004
    San Diego, CA
    Hmmm, and you just did cam chain tensioner? Will turn over and never start if you lost compression due to timing failure
    99 A4 1.8TQM Avant
    Aug 24 2016
    Sea
    Just timed it with a certified VW mechanic after replacement. Tried a few things and called it a night. Unfortunately for me(good for him) he just had another baby and wont have time to come over for a while which is understandable.
    Even with a timing failure, how would that affect the diagnostic port?
    May 08 2004
    San Diego, CA
    I’m at a loss. Maybe something in the wiring around the area you were working was pinched creating a short. Not sure what direction to go in. Good luck!
    99 A4 1.8TQM Avant
    Aug 24 2016
    Sea
    Me too. Was hoping for advice so I dont keep throwing parts against the wall.
    Orange County, CA
    Check fuses for OBD II to see. Mine sometimes has strange connection but I just turn the key off and back into electric and it works again.
    B5 Parts For Sale
    Nov 20 2016
    Philadelphia, PA
    Like everyone else said check the wires because the coil wires are back behind the valve cover and could of pinched and shorted them to ground. Doubtful since it did start but you never know
    Sent from my SM-N920T using Audizine mobile app
    Aug 24 2016
    Sea
    Ive checked all the fuses in the left dash panel. Ill try replacing the diagnostics fuse and disconnecting the ABS module next.
    Aug 24 2016
    Sea
    Quote Originally Posted by Bdkxracer17 View Post
    Ill check the valve cover and see if anything looks out of ordinary.
    Aug 24 2016
    Sea
    Checked the wires and nothing was pinched.
    Aug 24 2016
    Sea
    Quote Originally Posted by OverSpun View Post
    Ive previously checked all the fuses. Rechecked them today, everything looked normal.
    Tried to scan again, same deal.
    Unplugged the ABS sensor, scanned and nothing.
    Pulled the radio fuse, scanned and nothing.
    Ordered the radio pins so I can pull the radio and see if the fuse on the back is blown.
    Aug 24 2016
    Sea
    Took a while but I got the pins.
    Prior to leaving town(10am Saturday) for Easter weekend I pulled the radio and 7,5(brown) fuse was blown. Returned 11pm Monday night. Gonna spend Tuesday on it and see what I can find.
    Jun 30 2008
    Erie, Pennsylvania
    Are you getting spark? Assuming you are not getting spark:
    #1 - I would check to see if you are actually getting power (DURING starter cranking) at the Coil Packs pin #1 (Red/Green wire).
    #2 - If you are not getting power to the coil packs on pin #1 during cranking, I would then check if you are getting power to fuse #29 during cranking.
    (If #2 is easier for you to check on your own, go ahead and do that first)
    If you are not getting power at fuse #29 during cranking (and the fuse is not blown), I think you may have a faulty ECU Power Supply Relay. That relay (located next to the ECU) is responsible for powering 2 fuses:
    - Fuse 29 (20 Amp in the side fuse panel) that drives the coil packs
    - Fuse 204 (15 Amp in the ECU chamber) that drives the Cam Chain Tensioner solenoid
    This relay can fail suddenly and without warning. When failed they generally just fail to initially engage - they usually won't cut out while you're driving. Sometimes you can just tap on the relay and get it to work for a few more drives, but it's kind hard to get at.
    Aug 24 2016
    Sea
    Appreciate the info. I have previously swapped out both relays AND the computer in the ECU box. Relays were the first thing I tried.
    Unfortunately, I didnt get a chance to look around this afternoon. I'm hoping once I get a new radio fuse in there it will at least allow me to scan and diagnose? I was actually really happy when I saw that the fuse was blown. Theoretically, it should lead me in the right direction.
    I will double check those fuses once I swap the radio.
    Jun 30 2008
    Erie, Pennsylvania
    - I would definitely see if you have spark or not. That's an easy check that will tell us a lot of information.
    - Also, do you have a Check Engine Light coming on with Key On?
    If it isn't the ECU Power Supply Relay, I'm thinking the ECU might not be powering up.
    - Check all necessary power and ground to ECU, especially ECU pin 3 (Key Run/Start power via 10 Amp Fuse #7) and pin 62 (battery power, unfused).
    - Check to see if your ECU Power Supply Relay is energizing with key On. If not, maybe find out why (ie: missing power, missing ground trigger, done broke, etc.)
    Also, these are just internet armchair suggestions. So, certainly heed my signature and feel free to just "k thanks" and do your own thing.
    Aug 24 2016
    Sea
    Put a new fuse in the radio this evening. Radio turned on, still could not connect to the diagnostic port. Now Im confused.
    Will check out your suggestions and get back.
    Aug 24 2016
    Sea
    No spark. For the hell of it I put new plugs in just in case. Didnt help. Pulled and tested the relays in the ECU box, everything was fine. Havent had time to play with it in the past week other than that.
    Still wondering why I cant connect to the diagnostics port.
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Unplug the abs module under the hood and try connecting to the obd port. Mine has been disconnected for years, even clipped the k line wire from the radio harness because of aftermarket radio and Ive not had any trouble except for a blown fuse one time.
    1998.5 A4 1.8TQM My Build
    Jun 30 2008
    Erie, Pennsylvania
    No spark and no ECU communication. Sounds like ECU is dead or not getting power.
    - Do you have the Check Engine Light illuminated with Key on?
    - Did you check Fuse #7 / ECU Pin 3?
    - Did you check ECU pin 62?
    Aug 24 2016
    Sea
    Quote Originally Posted by xdewaynex View Post
    I did try that. Prior to finding the blown kwire fuse, and after.
    Aug 24 2016
    Sea
    I dont see CEL illuminated with key on but will definitely double check.
    -Tried swapping with another ECU. Same thing. Cranks and sounds great but wont turn over.
    -I check all the fuses multiple times but will check #7.
    -No I havent Checked Pin 3 or 62.
    Thanks, I have all weekend off and will see what I can come up with.
    Aug 24 2016
    Sea
    Bump.
    Aug 24 2016
    Sea
    It was fuse 7. Thank You walky_talky20
    Replaced and car fired right up. Diagnostics works as well.
    A true learning experience, I really hope this helps someone in the future.
    Jun 30 2008
    Erie, Pennsylvania
    Yep. Power and ground are pretty important! Glad you got it running again. And thanks for posting the solution.
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    If the k-line from the radio is crossed incorrectly, say you installed an aftermarket radio and incorrectly sent power to the k-line, it will disable your obd2 port. I'm pretty sure you have a BOSE symphony, so I doubt that was disabling it. Listen to Walky he is the electrical wizard.
    EDIT: I see he helped you out.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
    Aug 24 2016
    Sea
    Indeed.
    I just never would have guessed the Anti-Lock Brake System fuse controlled so much. I had previously checked all the fuses but the break was so small I must have just missed it.
    Jun 30 2008
    Erie, Pennsylvania
    This is a good reason to check fuses with a test light. Once in a while you can even get a fuse that looks fine, but is actually open. So you just turn the key on and just run through each fuse with a test light and make sure there is power on both sides. Just tap each contact. It's much quicker, too.
    Aug 24 2016
    Sea
    Appreciate it. Im learning and collecting tools as I go!
