Results 1 to 21 of 21
    Established Member Two Rings Gekko's Avatar
    Oct 18 2017
    2003 A4 1.8TQM, 2006 SV650
    NC
    Thumbs up Misfire after changing valve cover gasket (Solved)
    Hello knowledgeable people of audizine
    Last night I changed the VCG on my 2003 A4 1.8T for the second time. The first time I did this all went well. This time it has not. Everything goes pretty normal and uneventful until towards the end when my klutzy self drops a coilpack while carrying it back over to the car to reinstall. I almost caught it half way down, and it slowed it enough to where it only slightly bent the metal tip when it crashed down. It wasn't bad at all, and I was able to fix the minor bend myself with my hand. Reinstall everything and let the car sit overnight so the rtv can dry.
    Today I go to start it and it has what sounds like a misfire with a flashing check engine light. My first thoughts are the coilpack. So I double check all of my connections and it still does it. Run to autozone and grab a new coilpack to replace the one I dropped and this doesn't fix it. At this point I start the car and unplug packs one at a time to figure out which one is the issue. Cylinder 3 is the only one where unplugging the coilpack doesn't make a noticeable drop in rpm. Just for the hell of it I swap an old coilpack for the new one in that spot and it makes no difference. Everything was fine last night before I started this so it's something that happened when changing the gasket. Anyone have any ideas on what steps I should take next?
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Plugs? Or the coil harness cracking?
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Jan 24 2010
    Paramus,NJ USA
    Spark plugs!!Did you drop anything into the cylinder head???
    Ziddy Autowerks
    Oct 18 2017
    NC
    Just put new plugs in and same problem :(
    Oct 18 2017
    NC
    I'd like to add that when I took the plugs out I noticed a small amount of what looked like oil resting in the block right above the hole for sparkplugs tip/electrode.. If I had oil leak onto the cylinder head overnight would it run like shit for a few mins until it burned that out or no?
    Jan 24 2010
    Paramus,NJ USA
    Not unless you physically clean it out.Oil will not burn up as fast as you think in that space.It is possible thats your issue.
    Ziddy Autowerks
    Oct 18 2017
    NC
    Should I let it run?
    Jan 24 2010
    Paramus,NJ USA
    i would clean it out if you think there a good amount of oil in there.
    Ziddy Autowerks
    Oct 18 2017
    NC
    What's the recommended way?
    Jan 24 2010
    Paramus,NJ USA
    Well if you dont clean it and it has a misfire still you could be wasting your time looking for another problem.If you clean it its resolved then I guess your back in business.
    Ziddy Autowerks
    Oct 18 2017
    NC
    Quote Originally Posted by EuroxS4 View Post
    I'm sorry, I meant what was the recommended way of cleaning it out? I've never done anything like that before and don't know where to even begin.
    Jan 24 2010
    Paramus,NJ USA
    Oh ok absorbent towel or rag or blow it out with compressed air if you have air compressor put the rag over the orfice.That's what I normally do.
    Ziddy Autowerks
    Oct 18 2017
    NC
    Perfect, do you think I can pull this off without having to remove the VC again?
    Jan 24 2010
    Paramus,NJ USA
    Yeah the spark plug hole is pretty deep.I would just pull the coil out and clean inside.
    Ziddy Autowerks
    Veteran Member Four Rings egovreau's Avatar
    Sep 08 2015
    2017 Audi Q5, 1989 Jaguar XJS, 2005 Ford F-250, 2002 VW Passat Wagon
    Orting, WA
    With a small amount of oil in the cylinder, it would burn off within 30 seconds or less.
    You did say that removing #3 coil wires didn't result in a drop in RPM. If you know you have a known good coil and the plugs are good (you said new) then I would look at the wiring. Look for cracks in the insulation and connector. Unfortunately, swapping wires isn't a viable option. Or, at least, an easy one.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Oct 18 2017
    NC
    The well is clean, is it possible there is still some sitting on the cylinder head? I see a glistening but again, this is getting beyond my skill set.
    Oct 18 2017
    NC
    So I looked at the wire for cyl 3s coilpack. From the outside all looks fine. But then I pulled back the boot off the connector to find this beauty.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    Hey Arachnid, the engine will run like shite if the PCV hoses are disconnected from the valve covers. Did you click the plastic elbows back into place on the valve covers (firewall end) after you replaced the gaskets?
    Quote Originally Posted by Arachnid View Post
    The oil is not causing the misfires. As egovreau said, "With a small amount of oil in the cylinder, it would burn off within 30 seconds or less."
    Oct 18 2017
    NC
    Quote Originally Posted by john_gonzo View Post
    I know everything pcv-wise that I unhooked yesterday I reconnected including the ones that connect directly to the valve cover. I'm guessing it is possible with all the tugging I did that something could have come loose further down the tubes. I'll be looking into this today while I decide what to do about the potential wire issue.
    Oct 18 2017
    NC
    Just a final update for anyone that comes across this. Visited my friendly mechanic to have the codes read. We ended up finding out it wasn't the coilpack harness but instead the wires that go to the injector connector had completely broken off. Anyone in a similar situation might as well add that to the list of things to check.
    Thank you to everyone who posted and tried to help me track this gremlin down!
    Sep 08 2015
    Orting, WA
    Yep, that can happen too.
