Results 1 to 15 of 15
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    balance shaft alignment
    So does anyone have any data regarding what position the balance shafts are supposed to be in with the #1 cylinder at TDC? The marks on the gears were completely out no matter which way i rotated the assembly, i suspect that the last time the rebuilt the engine they were a little off with putting these into the correct position, the one gear was upside down. I have a chart but the gears do not have the same marks the chart seems to indicate they should have.
    Nov 20 2016
    diagram im using for reference
    Dec 06 2008
    04 A4 Avant 1.8t quattro tiptronic
    Orangeville
    It looks about the same with the one I used. I used a manual from manuals.com/audi/
    When I took the engine apart, no matter how many revolutions I turned it, I never made the balance shaft align. After I timed it myself, they were coming back into alignment every time. It takes ALOT of revolutions for everything to line up again.
    Sent from my SM-G950W using Tapatalk
    Quartz Grey '10 A4 Avant Quattro 2.0 Prestige - 267000 KM
    Red '04 A4 Avant Quattro 1.8T tiptronic - 264000 KM
    Ice Silver 2014 Q5 premium - 64000 KM
    Today is a gift, that's why it's called THE PRESENT!
    Life is not about the amount of breaths you take. It is the moments that take your breath away.
    Nov 20 2016
    Quote Originally Posted by doc_oc View Post
    cant seem to find those tiny dots however on that double sided sprocket, i see the large one for the chains colored link, but not the ones that pair to the actual balance shaft itself, i also have another problem because like a dumbass i accidently dissasembled the cam actuator too, and the pin fell out and im not sure if the pin slides through the spring, or the plunger pushes against the spring. lol
    Feb 24 2004
    Minneapolis
    This help you at all Spawne32?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Feb 24 2004
    Minneapolis
    This isn't timed right, but it does show the marks you're looking for.
    Nov 20 2016
    yeh that one i can see, they seem to indicate smaller ones on the teeth side of the second part of the gear that meshes with the balance shaft it self that should keep the balance shaft in alignment, if they are on there, i cant see them, only thing i see now in the picture is on the bottom left by my thumb on one of the edges of the teeth on the curved gear set, looks like a dot.
    Nov 24 2013
    NYS
    This is what I saw when I was replacing my timing chain :
    Sent from my SM-G930V using Audizine mobile app
    Established Member Two Rings tech30six's Avatar
    Sep 22 2016
    Kitchener-Waterloo, Ontario
    Quote Originally Posted by palmface View Post
    This is the correct installation and timing position of the balance shafts.
    Sent from my LG-H915 using Audizine mobile app
    Sep 22 2016
    You can see the single dot just above the white paint. The actual valve timing is separate from the balance shaft timing. Once the shafts are timed, just time your timing chain to the 3 marks on the chain, to the 2 marks on the cam, and the 1 on the crank. As long as those 3 marks line up, they will always be timed. No need to put it to exact tdc. The 3 marks on the timing chain make valve timing idiot proof.
    Nov 20 2016
    Thanks yeh, when i went back this morning i saw them plain as day, must have just been tired
    Dec 03 2016
    nowhere
    Great that you're doing this. Hope all goes well.
    HEAR
    APR stage 2
    Established Member Two Rings RHawk's Avatar
    Feb 23 2018
    '19 Subaru WRX
    Mundelein, il
    If the gears are not synced, how does the engine not rattle to pieces?
    Sent from my HTC6535LVW using Audizine mobile app
    Sep 22 2016
    Quote Originally Posted by Spawne32 View Post
    Awesome. Good luck man.
    Nov 20 2016
    Quote Originally Posted by RHawk View Post
    I don't know that balance shafts necessarily cause a "rattle", they deal with small harmonic vibrations. To my understanding it would be detrimental to the bearings more then it would be to the seat of my pants. You could have balance shafts out of time and the engine mounts soak up most of the small vibrations from that imbalance. Car idles alot smoother now for whatever reason. Possible they were timed right but the dots just dont line up, even though I would have expected them to.
