Having an issue where the coolant system is pressurizing under boost and blowing coolant out of the expansion tank. Driving normally it’s fine. It can sit and idle fine, cruise fine, mixed driving it's fine, doesn’t burn any coolant and level remains the same when driving normally. The coolant is nice and pink too. But if you get on it it’s spews coolant from the tank. I did notice however, the cap doesn’t “click” into place like it used to. That seems odd so I’m buying a new oem tank and cap and seeing if that helps. After it dumps coolant, I can pull over, pop the cap off and the coolant level rises, but it doesn't come blowing out or overflow. It's not boiling either.
The car doesn’t misfire under full boost and runs great. Cold starts just fine, drives around fine, no smoke from the exhaust. I don’t get what’s pressurizing the system. I would think combustion gases getting into the system would pressurize it all the time, not just in boost. I would also think combustion gases leaking into the cooling system would cause misfires. I was under the impression the cooling system was always under the same pressure once up to operating temp. Thinking back now though, anytime I blew a rad hose off, it's always been at full tilt, never under light throttle. Idk. Head lifting under boost? Seems unlikely though. I used OEM head bolts, and the motor was assembled professionally by Zillarob.
Fuck this car, any input is appreciated.
