Results 1 to 4 of 4
    Sep 04 2011
    Central NJ
    VCDS: Address 17 Instruments No Basic Setting
    Today I wanted to reset my service interval that has been bugging me for a few days now. So I went into VCDS SRI Reset and did both the ESI reset and the Fix North America reset, if I recall the wording correctly. Anyway, the ESI values seem to have reset but the FIX values didn't. So I went into 17 Instruments - Adaptation and increased the FIX maximum days til service to 750 without a problem. I also changed ESI reset to reset without problem. Then I did an auto scan and found the error below. I tried to clear it but I can't. Does anyone know what that fault code means and how I can fix the "no basic setting" in VCDS? I'm not sure if this is related to me fooling around with the service intervals, especially the automatic VCDS procedures but I would suspect so. Any help would be much appreciated.
    Address 17: Instruments (J285) Labels:. 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G0 920 982 L HW: 4G0 920 982 L
    Component: TBenUsaAccNv H11 0106
    Revision: 08001098 Serial number: 658200116596028
    Coding: 0BCF0905BF51D705020200
    Shop #: WSC 22497 002 104857
    ASAM Dataset: EV_RBD4K 004055
    ROD: EV_RBD4K.rod
    VCID: 3522EDEC94F56CECFB-8060
    1 Fault Found:
    1048578 - No Basic Setting
    B2010 00 [009] - -
    [Steuergerät keine oder falsche Grundeinstellung / Adaption]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 16550 km
    Date: 2018.02.11
    Time: 17:23:00
    Update: Did a proper reset of all values (i.e. time and distance since last service to zero, max time interval to 365, oil quality to good, and esi reset again) and the fault code is gone. Should have checked the VCDS forum before posting here. Anyway, the post can still be helpful for future reference if someone does a half-ass service interval reset like I did and then ends up with a fault code.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Jan 29 2019
    The Netherlands
    Hey,
    I have 1048578 - No Basic Setting also in 17.
    Any news about it now? I did a reset after I did the oil and filter changes. I did it with the 0.0/reset button between the gauges. I did reset oil service, and also inspection. However, before resetting I had Good oil Quality, now I read Bad Oil Quality in the SRI menu in the main-vcds screen.
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    I've need to reset mine for past 500 miles as well, good to know.
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
    Sep 04 2011
    Central NJ
    Quote Originally Posted by prosier View Post
    Hey,
    No fault codes anymore after I reset all values as described in my update. Give it a try and let us know if it fixes your issue as well.
