Results 1 to 11 of 11
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Powerstop Brakes
    Curious if anyone has used this kit https://www.powerstop.com/product/po...&mk=AUDI&mo=S4
    And yes I did look and can’t find much info from Audi members. Also if anyone would recommend something else in a similar price range that would be great too. Thank you.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I use PowerStop Z26 pads on my Corvette, and I am happy with them, brake dust went from horrific (Ferodo/Brembo pads) to minimal.....but they are not for track use.
    I put Akebono pads on my S4, also to reduce the brake dust, they are good too.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Yeah I looked at the z26 package but they don’t have it for the s4. What rotors did you use with the akebonos?
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Quote Originally Posted by S4'ed View Post
    And how is stopping compared to stock pads?
    Sep 24 2014
    Central NJ
    S4 : Stock rotors with the Akebonos. They have less initial bite than the factory pads, but they are more linear. It take a some getting used-to when you swap, but a few drives and everything seems "normal" again.
    Corvette : Stock rotors with PowerStop Z26. Brake feel seems 95% the same to me.
    If you want to change your S4 rotors, just buy some Zimmermans. "Upgraded" rotors for street use are not needed.
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Yeah that’s what I was afraid of, I like the bite of the stock pads. Is anything compatible?
    Veteran Member Four Rings TFSI's Avatar
    Dec 16 2009
    Some car
    MD
    I've used them on my previous cars. Good price and worked well for my purpose. If this is for daily-driven car, then that should work fine. Paint the rotor hubs if you don't want to see ugly rust.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Quote Originally Posted by TFSI View Post
    Or go with their "Cryo" Rotors... They come with the hubs painted black and the entire rotor is Cryo Treated which makes it much more resistant to rust - as well as less effected by pad debris sticking to the rotor and causing brake shudder (many think this is warped rotors)....
    I've had these on my DD Subaru for 2 winters now and they look brand new - Partnered with Porterfield R4-S Pads it's the perfect DD Braking setup! (Excellent stopping power & low dust)
    Will be putting the same on the S4 once the car is ready for new brakes!
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Powerstop Brakes
    Quote Originally Posted by grovlet View Post
    Do you have a link to the ones you mentioned? Interested in checking these out before I make a final decision.
    Edit
    Found these
    http://m.autoanything.com/brakes/sto...icleId=3271543
    This what you’re talking about?
    Dec 16 2009
    Some car
    MD
    Centric/stoptech carries them
    Dec 19 2004
    I have those on my MK 6 Golf R. They perform the same as stock, but make way less dust.
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
