Results 1 to 19 of 19
    Nov 28 2015
    Montreal, QC
    Brisk or NGK spark Plug ?
    So I'm due for a service this spring. Should I re-order NGK oem plug or go for Brisk ? Apparently, this plug is the sh*t to buy. Anyone has supporting data for this ? Are these silver plug good for north weather ? ( -20celcius )
    Let's discuss :)
    S4 B8.5 no track, just enjoying spirited driving.
    Nov 02 2015
    Orlando, FL
    I'm been running the Brisk plugs for a couple months now, no issues whatsoever. I'm in Orlando, FL so no clue about -20c weather ;)
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    NGK'S will last longer, due to the metal's higher density. This higher density may also have a longer peak performance lifespan, as the hard edges will stay in tact longer (electricity likes to jump to sharp edges).
    Brisk uses silver, which is far superior at carrying a stronger spark. Roughly, Brisks should last 2-3x longer than copper, but half as long as stock NGK's.
    Here are the conductivity numbers of the different metals available for spark plugs:
    Platinum 70 k
    Nickel 91 k
    Iridium 147 k
    Copper is 401 k
    Silver is 429 k
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Nov 28 2015
    Montreal, QC
    as long as they can last 2years or so, which equals to about 20,000km for me, I'm totally fine :)
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Do you guys know the brisk plug #.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Nov 02 2015
    Orlando, FL
    Dec 29 2011
    The Bay
    ^^Thanks 👍
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    So who's running the Brisk?
    '18 S5 - BBS / EPL
    Apr 26 2017
    GLS 450
    Nashville, TN
    Quote Originally Posted by JD S4 View Post
    S4matty is who recommended them. I am running them, and so are a few others.
    Previous
    May 07 2016
    Quote Originally Posted by brs2c View Post
    how long? performance? logs ok?
    '18 S5 - BBS / EPL
    Apr 26 2017
    GLS 450
    Nashville, TN
    I just put mine in at 50k miles over the stockers on DP. Huge gain in 'peppyness', but it is hard to know how much of that was due to silver being a far superior conductor, vs to going from old plugs that were incorrectly gapped for DP, to new correctly gapped plugs.
    I am finally getting my VAGCOM, back from my buddy tomorrow evening. I am dying to do some logging. I think S4matty had great logs, on them.
    Previous
    May 07 2016
    Thanks for the tips/info.
    '18 S5 - BBS / EPL
    Nov 28 2015
    Montreal, QC
    do you use the same 0.26 gap on the brisk plug ?
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by waxxonMTL View Post
    My friend Geoff has been running his for 1.5yrs now on same set and no issues at all.
    I was having issues with mine but ended up being 2 bad coils.
    You will love these plugs
    There's a noticeable difference in response with them over stock plugs.
    Sent from my SM-G950W using Audizine mobile app
    Nov 28 2015
    Montreal, QC
    i found a retailer in canada, so im waiting for invoice :) im due for a FULL service this spring ( belt, fluid, plug, filter) i hope to feel the car a bit more peppy :)
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    Waxxon how much mileage on your car?
    Murdered B8.5 S4
    Build Thread
    Jun 07 2015
    Madison, WI
    Quote Originally Posted by chrisucf99 View Post
    This number is listed as a stock replacement, what about APR's suggestion of running a step colder for the Ultracharger guys like yourself?
    2010 GTI APR Stage 3 K04, VWR springs, UniBrace.
    2013 Golf R APR Stage 2, APR DSG Tune.
    2012 B8 S4 DSG Sport diff. APR Stage 2 V4.0, APR TCU tune, JHM 187 lower pulley, Modded air box, silicone tube, CR-15 (sold).
    2019 S4 APR Stg 1 tune, TCU tune, intake, FMIC, 034 Rear bar, ECS inserts, Koni Special Active Red shocks, 034 shock mounts, Mops 10/12 spacers.
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by davesxx01 View Post
    You would want the DR10YS then
    That works out to a 9 heat range in ngk.
    My car is a 2010 and came with 7's stock and seems very happy with the uc 104 file.
    So I already jumped 1 step colder using the DR12'S
    I'm going to try the 10's soon though and see how she likes them
    Sep 28 2017
    Attleboro
    Quote Originally Posted by s4matty View Post
    s4matty what do you recommend for gap on the brisk plugs?
    Sent from my SM-N950U using Audizine mobile app
