Originally Posted by
timzcat
Whatever drive mode I shut off in is what I start up in.
timzcat
I only ever drive in Sport for transmission but know of no way to have it be in Sport unless I pull back on shifter.
Just contradicted yourself. According to you, car starts up in dynamic (sport), but you have to pull it back for dynamic (sport). Car didn't start up in dynamic (sport) then. The screen may say you're in dynamic, but you're not.
It's not really up for debate. It's been proven time and time again across multiple models across multiple model years that this is how Audi designs their vehicles. Some speculate Audi does it for fuel economy reasons. If you were the average Joe driver who shifted from P to D every day and refused to give 2 shits about the systems and options available to you, you could find yourself not meeting Audi's claimed MPG because you somehow accidentally put yourself in dynamic mode and are now driving in sport 24/7. Multiple owners have found no matter the class (RS, S, A/Q), Audi will reset the engine and exhaust to auto mode upon turning off the vehicle, no matter what mode you were in. You have to either re-select the mode upon start-up or shift manually into "S" again to put it back to how you left it.
My initial comment was that if you have to do that anyway to put the engine back into sport mode (and potentially other systems such as quattro/differential), it would be somewhat of a waste to drop $400 on a module that does absolutely nothing to change your start-up routine.
timzcat
You realize what you wrote that when you start the trans is not in Sport mode, well its in Park? lol
Clearly. The point is, if the vehicle is properly in dynamic, when you shift from P to D, it will be in sport mode (not "D" mode). However, when you start-up the vehicle in dynamic, when you shift to P to D, it will be in auto mode ("D" mode). You have to pull the shifter again to get it in sport mode. That means the car is not actually in dynamic mode. See my point above. Audi did this specifically so you would have to take an extra step to confirm you want it in dynamic mode again, despite you ending your last trip in dynamic mode.
Give it a try. When already in "S" mode, shift to "P". Then shift back to drive, and you'll see you're back in "S" with no extra shifting needed. That's the engine in proper dynamic mode. That doesn't happen when you start-up the car and shift for the first time.
timzcat
I never have to touch my exhaust button. I just start it and pull back for sport once in drive and I am good.
Correct. Thus there are three ways Audi gives you to put the exhaust in dynamic mode after starting up the vehicle. 1) Click the exhaust button 2) Re-select dynamic (or individual if set properly) mode 3) Shift the transmission into "S"
All three methods will put the exhaust in dynamic mode, however, not all three methods do the same thing. Method #1 only puts the exhaust in (or out of) dynamic mode. Method #2 puts
everything (steering, suspension, quattro, engine, exhaust) in dynamic mode. Method #3 puts the engine and exhaust in dynamic mode. All three get the exhaust to dynamic mode, but all three give you different results for other parts of the vehicle.
The point is all three methods are ways to put your exhaust in dynamic mode, but no matter what, both exhaust and engine will start in auto mode when you start the vehicle up.
Hope I was able to relieve the confusion you experienced.
