So i had this issue on my left tailpipe a year ago, meanly that the valve would not open.
I had grinded the lip a bit and in the end i got it sorted, no issues and normal behaving valve.
Untill i few weeks ago inspected my right valve...I'll be damned, now it is the right one that is blocked!!
I tried to contact Milltek, sended them video and explained what the malfunction is.....no help from them since then :(.
Anyway, so Milltek has this 'lock' feature, witch is basicly a spring that is pushing the valve upwards into a very thinny grove in the tailpipe.
Once you install your OEM actuator with the stock turning spring, that spring should counter force the milltek spring and freely open/close the valve.
.....In theory, but in reality the stock spring is not strong enough or wears out over time so the milltek spring is too strong and thus keep the valve locked (without you knowing it...and maybe risk unbalanced pressure in exhaust system. Afaik the ECU has a engine protection mode to always open the valve under heavy load...unless Milltek designs a valve that fails!!).
Anyways, since Milltek doesn't man up, looks i'll have to do it myself.
Does anybody know if that milltek spring would be located underneat the valve rod? There is this extra piece, i suspect it is a hallow tube containing a spring. About to grind the bastard off....
For your information, i had recently put my stock exahust on and OEM valves don't have this extra piece under the valve NOR does it need force to push the valve downards before opening. Not sure why Milltek added this in the first place (maybe for anti-rattling valve noise).
Added small movie of the blocked valve and the downwards pushing to open it. With my hand it works, but the stock spring isn't strong enough (sadely new spring isn't sold seperatly).
*nevermind the movie, it was too big and couldn't upload :(.
