Results 1 to 24 of 24
    Jun 05 2004
    Connecticut
    Audi S3 Magnetic Ride Longevity?
    Hi all,
    I will likely be purchasing a new Audi S3 in the near future and am wondering about the longevity of the magnetic suspension. How long does it last before it needs to be replaced and what is the replacement cost? Also, are there aftermarket alternatives?
    I usually keep my cars for 10+ years and am trying to get an idea of future repair costs.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i was wondering the same thing.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Established Member Two Rings PsiBlast's Avatar
    Jun 08 2015
    I read up on this a while ago on an R8 forum, and it seems the magride shocks were priced around $750 (yes, each).
    2016 Audi S3 Premium Plus | Sepang Blue Pearl Effect / Black Interior | Technology package | 19" Performance package | Bang & Olufsen Sound System
    MSS Sports Fully Adjustable Spring Kit | 034Motorsport Stage 1 | 034Motorsport rear subframe mount inserts | 034Motorsport dogbone mount insert | Resonator delete
    Veteran Member Three Rings jiannu's Avatar
    Mar 23 2016
    Ontario,Canada
    Quote Originally Posted by PsiBlast View Post
    For that $$$$ I would just invest in a great aftermarket coilover kit. If ordering a new S3, I would avoid the magride.
    Oct 30 2016
    Sacramento, CA
    Just a guess, I'm thinking it might go out early since these S3's are riding on low profile tires. The shocks are working harder since their is less rubber to absorb the impacts.
    Junior Member Two Rings
    Feb 14 2018
    San Diego, CA
    Quote Originally Posted by nothome17 View Post
    Yikes you're making me regret going with 19" :(
    At least my next set of tires will be 245/35/19 in order to get more sidewall if it isn't too much hassle on the 19" black optic wheels.
    '18 GWM S3 / Tech Pkg / Black Optic Pkg / S Sport Seats / S Sport Pkg / Audi Beam Quattro /
    Mods IE Stage II ECU-TCU / IE Downpipe / 034 Carbon Fiber Intake and Air Duct / Unitronic Turbo Inlet Pipe / EMD Carbon Fiber Front Splitter / eMMOTION Rear Sway Bar kit and Link Kit / APR A01 Wheels 19x8.5 ET45 w/ 245/35R19 Michelin Pilot Sport 4S /
    Nov 13 2009
    the OC, SOCAL
    the car is not 10 years old yet. no real data available.
    the one thing is if you put aftermarket springs in it while still having the mag ride shocks, they will go out much sooner.
    most shocks in the market last around 4-6 years and need to be replaced, but that doesn't let many rebels to still drive on the blown out shocks years after that.
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by c0ld View Post
    If you go the route of 245/35/19, make sure you never use your donut spare. The donut spare is design to have the same rolling circumference as the OE 235/35/19. Having a dissimilar tire rolling circumference can place additional stress on the drive train of an AWD system (differential, Haldex, etc). This is something that most people don't think about.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Feb 16 2004
    Bay Area
    Quote Originally Posted by XMetal View Post
    The spare tire is .6" shorter than the OE 235/35/19. The spare is actually closer in size to the OE 18" tire size than the 19."
    The current gen of MR shocks are far more durable than what the R8 had. If we could only get DSC Sport to create a shock controller for this platform we could have a fully adjustable, dynamically reacting shock that surpasses any off the shelf available shock.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    Active Member One Ring Audi128's Avatar
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Sorry for reviving this old thread but has anyone had their dampers go out? If so what mileage were you at?
    I’m currently contemplating installing some aftermarket springs with the MR dampers but I’m at 85,000km (53,000 miles). I’m conflicted because I’d probably just replace the whole system with some coil overs if the dampers ever wear out.
    Should I just risk installing the springs or wait and get some coils down the line?
    Dec 25 2004
    Earth
    Quote Originally Posted by Audi128 View Post
    Once you see the price of each MAG ride shock...
    Mine were at 103,000...
    I removed and replaced them with a set of shocks taken of an RS3 with 16 miles on them...paid $200 for all 4 shocks and springs.
    I like the RS3 shocks better. I also have 034 springs.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Oct 10 2016
    Houston, TX
    If you can DIY the spring install (and don't mind the time), you can start with a set of springs. I just switched to coilovers. 34k miles on the MagRide shocks, and I think about 12k of that was with 034 springs. The shocks had plenty of life left in them. Hard to say how much life is left at 53k miles, but if labor isn't a factor springs are cheap and you can ride them until you need replacements.
    If you are going to get a shop to perform the work, I would jump to coilovers right now. It's an expensive job, and coilovers are not really any more expensive to install than springs. If you put springs on the aged suspension, you don't know how much life you can get out of them before you have to pay for labor again. I'd replace it all now so hopefully you don't have to pay for the same job twice. Remember to get the MagRide cancellers if you go pull the MagRide shocks out.
    Dec 25 2004
    Earth
    Yes...the isweep cancellers I have work perfectly.
    The Golf R platform has ACC shocks...and Bilstein makes replacement for them...we need more MAG ride shock selections vise only OE Factory $$$$$$$
    Also we need the secret to code out the MAG ride with VCDS so we dont have to buy cancellers!
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Quote Originally Posted by MikTip View Post
    103,000 miles or kilometers? Were the RS3 shocks mag ride as well or were they just standard shocks? This is the first time hearing about an RS3 shock swap so I'm a little unfamiliar with this.
    2006 Silver Audi S4 B7:Stock
    2008 Silver Lexus IS-F: Blacked out badges, yellow fog lights and tinted windows
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Quote Originally Posted by lastig21 View Post
    I have to do a brake pad and rotor replacement pretty soon because I'm still on oem parts. I'm just trying to see if its worth it to do both brakes and springs at the same time since the car will be up in the air at the shop.
    Thanks lastig and miktip for the advice. It definitely will affect my decisions on this car.
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    @MikTip
    Yup I'm quite aware of the versatility of the MQB chassis. I was just wondering if there was any differences between the S3 and RS3 dampers because although they are the same chassis, I wasn't completely sure if they will fit as the RS3 is a facelifted model. How do the RS3 dampers compare to the factory Mag ride ones?
    Veteran Member Three Rings TheDude420's Avatar
    Mar 07 2018
    S3
    Florida
    I have mag-ride on my 2016 S3 and I'm using 034 Motorsport Dynamic Lowering Springs which provide a 0.75" drop. I like them but I've only owned the car since February 2019 so I don't have anything to compare it to. I don't know enough about suspensions to know whether my struts/shocks are blown. What is the lowest I can go on springs with mag-ride while avoiding H&R? If I was just 0.25" lower I'd be happy.
    2016 S3 P+, Tech Pack, Black Optics, Super Sport Seats, Mag-Ride, Facelift-Style Headlights, APR Stage 2 High Torque & DSG Tune, Carbon fiber Intake, Intercooler, RS3 Coils, RS7 Spark Plugs, Boost Hose System w/Bypass Hose, Catch Can, AWE Downpipe, AWE Switchpath Exhaust, 034 Motorsport Dynamic Lowering Springs, RSB End Links, Neuspeed RSE102, Dogbone Mount Insert, Neuspeed Rear Sway Bar, EMD Carbon Fiber Diffuser, Carbon Fiber Spoiler, Milltek Cerakote Black GT-100 Exhaust Tips
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Quote Originally Posted by TheDude420 View Post
    Usually blown shocks will make the car bouncy, or bouncier than it should be in our case. There should also be some audible differences when going over bumps and it may leak visually if you inspect the damper itself. Personally, I have not driven on blown shocks yet so I can be that specific about how they should feel.
    On a side note since yours is a pre facelift, whats your mileage currently?
    Dec 25 2004
    Earth
    @MikTip
    I like the RS3 shocks over the MAG ride shocks...
    They are made by SACH Germany...came off a first US version RS3...
    I was going to buy a set of Sport Bilsteins...which I will probably do when these RS3 shocks go bad...
    Most folks here buy coil-overs...which is good as the shocks and springs are matched and are fully adjustable to your individual tastes on suspension.
    Mar 07 2018
    S3
    Florida
    Yes it's a pre-facelift 2016 model. I bought it from the owner at 44k miles and is now at 62k miles. The car has been very well maintained.
    Sent from my SM-G981U1 using Audizine mobile app
    Junior Member One Ring
    Apr 17 2018
    Winter Park, Fl
    I have a 16 with mag ride. I bought the car with 31k miles and H&R super sports were on it already. I have 61k now and the car is starting to get pretty bouncy. They are going to need to be replaced soon. I may use the short Bilsteins or maybe some RS3 shocks if I can find them.
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Quote Originally Posted by Quantim0 View Post
    Which Bilsteins were you thinking of? The bouncyness could be the dampers wearing out but maybe inspect them for any leaks to see how severe it is.
    Apr 17 2018
    Winter Park, Fl
    https://www.ecstuning.com/b-bilstein...t/35-229919kt/
    These since they are for lowering springs. The bounce isn't too bad, but it's definitely worse that it was a year ago. I can't imagine anything is leaking because that should create a clunk as the piston moves in the housing. Had it happen with another car, it's pretty distinctive.
    Jun 27 2011
    2008 Lexus IS-F
    Vancouver
    Ah I see which ones they were, I saw that they offered a B6 and a B8 model for those dampers but it was not specified which ones were in the set you linked. It appears that the part number for that matches up with the B8 model. If you do replace your shocks with these, please update us with your impressions.
