The parts I used from a B7 2.0T are the following:
059 145 814 B - B7 Intercooler bracket
8E0 145 806 M - B7 Passenger intercooler
8E0 145 708 K - B7 Passenger IC to cross over silicon piping
8E0 199 521 EB - B7 IC to IC metal cross over tube
8E0 117 336 N - B7 S-line Intercooler shroud (rev J is for non-sline bumpers) Regardless, I needed to cut it up. 8E0 117 336 C might not require cutting but not sure.
8E0 807 682 - Vented fog light grille, or modify your own, or grab them off ebay super cheap
A vented wheel well liner is also recommended but was never an options from the factory on the B6s. so you would have to graft one from a B5S4, a TT or a GTI 1JM 809 962 A, or anything really that had them.
You retain your stock turbo outlet silicon pipe, but need to modify the DV. I ended up relocating mine near the TB, which I have another chapter on elsewhere.
You will need to relocate your Secondary Air Injection(SAI) pump to facilitate this. Or you can completely delete it. The function of the SAI system is to help get the catalytic converter up to temperature faster in order to reduce start up emissions. This was required in order for the 1.8T to obtain a Ultra Low Emissions(ULEV) rating. If you just delete the SAI pump/hoses/install block off plate, you will end up with a MIL light. No amount of vagcomming can code this out. You will need to flash your ECU. This is primarily why I decided to keep mine for now.
The new location for the SAI ends up where the boost reservoir/Helmholtz resonator is mounted. The Helmholtz res gets deleted entirely. You will need shorter bolts to mount the new SAI mounting bracket, or cut the old reservoir bolts.
To start, you need to remove headlights, bumper and the rad support completely. Primarily because the IC to IC crossover tube needs to be swapped, and the power steering lines run through it and secondly it makes everything so much easier to work on. I left my AC lines connected, and worked around the condenser on the ground.
Start by making room for the SAI pump, this is the targeted location:
Everything removed:
I sourced a bracket from a A6 C5 : 8D0 906 615 B
You will need to cut up the bracket and drill one hole to get it to fit, I cut it a lot more than shown, and the hardware used is shown in the pic:
Then needed to tap an existing hole in the block, and you can see where my top bolt and nut combo is.
The original electrical harness will reach the new location. The SAI intake pipe needs to be lengthened about 8", and the outlet hose needs a 90 degree elbow cut into it. I used 3/4" heater hose for the intake pipe and gooed it together, and I used a 90 degree plastic PVC PEX fitting and glue it together. I am not looking to get 100,000km out of this set up so I am sure there some more permanent/indestructible solutions, but I digress:
This is the outlet pipe already installed:
Once the SAI is installed, it almost looks like it belongs there:
Once that is out of the way. Install the B7 IC gear. It all fits like OEM should and there really isnt anything to it. The turbo discharge only needs to rotate 90 degrees:
In the pics above, you can see a copper plug where the DV use to be. If you want to retain your stock location, you'll need to get a 90 degree 1-1/4" fitting and some heater hose to suite. I took this opportunity to relocate it closer to the TB.
Test fitting it all:
Lastly, you need to swap the cross over tube in the rad support. Here is the core with the B7 tube already installed:
Note the passenger side tube variance, the B7 points up and the B6 remains flat. I snapped both lower fan shroud bolts removing them...
Slam the core back on, and button up the front. Dont forget to top up the power steering fluid and boot it up. I never logged any data, but maybe I will beside one of my buddies cars that is still stock.
Here is the shroud that needs to be trimmed:
Before:
After:
And some reference diagrams:
B6:
B7:
I also attempted the B7 driver side IC swap as it has two additional rows, but deemed it not worth while. Documented in this thread, starts around post 11.
