    Veteran Member Three Rings ElliottG's Avatar
    Apr 30 2009
    '12 Q5 2.0T
    Key fob battery CR1620 or CR2032?
    Hi guys
    I have a fob like this for my car:
    The last time I changed the batteries, I put in CR1620's because that's what it had in it before from the P.O.
    Looking online, it seems that some people put in 2032's, and some people put in 1620's.
    The 1620's can move a bit in the case itself, making me think (from looking at the specs of the 2032's online), that the 2032's might be able to fit. Altough the 2032's are quite a bit thicker than the 1620's.
    Does anyone know what batteries are suppose to be in these fobs from the factory? And if CR2032's can fit in them?
    Thanks,
    Elliott
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    original fobs were little guys x2. Ebay junkers and or b6+ 2032
    (edit:I'll tell you right off the bat my capacity vs vcc is backwards parallel /series swapped)
    old fob 1620 x2 ((3.2v's I thought which is what threw me off))
    recently manufactured old style fob 2032 x1
    old fob guts in new style 2032 x1
    The x2 is only increasing capacity not voltage so two little guys are close in mAh i'd imagine.
    Huge size difference that is hard to see completely without digging through my garbage for a 1620 to compare.
    Nov 14 2011
    NW
    both same width and 3v. cr2032 and cr2016 on the right
    Established Member Two Rings BigTuna817's Avatar
    Sep 23 2012
    I used a 2032, worked fine for me.
    00 B5 S4 Stage 2
    Milltek Superdual, SSAC DPs, Darintake, "Chipped", JHM Short Throw, Forge DVs
    Veteran Member Four Rings thedanplasse's Avatar
    Apr 05 2016
    RI
    16XX is a smaller diameter. 1632 is thicker than the 1620, and 1620 is thicker than the 1616, but they're all the same diameter.
    They also make them in 20XX. 2032 is thicker than 2025, and that is thicker than the 2016. So if its a 16XX the 20XX wont fit. My fob had two 1620's in it.
    "Better stick to your A4 forum, peasant."
    Santorin Avant Project
    Atlas Avant Daily
