Originally Posted by
siyman4
Wow Mike thanks for all the great info. I'm more looking to do more back to back wide open throttle runs and not really quarter mile runs so I think a Heat exchanger would be more preferable. How much usually does a heat exchanger setup cost for parts + labor? And also what else would I need to buy other than the actual heat exchanger?
Ive missed the S4 forum alot lately so I'm not going to tell you to search the forums lol.
Heat exhangers can be had anywhere from $200 all int to $2000 all in.
For $150 you can get the Merc Racing add-on heat exhanger and run it as a compliment to your current hx. You'd need another 20 bucks worth of brackets and 3/4 on hose and you'd be done. There are some members who have gotten REALLY decent results with this actually. I wouldnt rule it out.
For around $450 I think you can get the Merc Racing quad pass hx that will completely replace yours and likely will work out really well. My understanding is you can get the brackets and everything included now. Just search the merc racing thread and email Jose.
For around $1000 you can get the Revo and/or the APR unit. They are also plug and play and replace your factory hx.
For a bunch more money you can get the full AWE or AMS kits. They give you the heat exchanger, crappy add on water pumps, reservoirs, the whole shebang.
If you were to go the Merc Racing option, you could stop there and run your setup like the OEM non divorced setup with your SC coolant loop connected to the engine coolant loop.
For an extra 20 bucks though you could by an Audi overflow tank for the supercharger loop and divorce the loops...
http://www.audizine.com/forum/showth...oolant-sensors
As far as installation, in general this is a pretty darn easy install. You only need to remove the front bumper. Everything is pretty accessible. The only snag people really hit is stripping out the plastic bleed screws on the supercharger. Order some replacement ones or get some metal ones. If you stop them...dont panic. Just shove a hot screwedriver down into the plastic shaft of the bleed screw and gently turn it out of the hole. Itll work. You could have it installed in a couple hours.
Mike
