Results 1 to 16 of 16
    Junior Member Two Rings
    Mar 09 2014
    Door Panel Rattle
    Took my car to the dealership to fix a door rattle, they took the door off, placed some "extra insulation" under there and of course everything is just worse now.
    Had a few questions about the door panels since I'm going to fix it myself.
    Saw a bunch of good guides: http://www.audizine.com/forum/showth...ith-remote-fob
    If the clips are broken (I suspect they are) are these easy to replace?
    If I end up needing a new door panel, is it possible to swap the leather armrest and the colored side inlay from mine onto one I buy? Or is it all one piece?
    Thanks
    May 20 2010
    The clips are easy to replace. You should be able to find them on ECS. I actual arm rest is usually easy to swap over. It's usually a few screws on the reverse side. The inlay, on the other hand, I'm not sure about.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Check out this thread from Audi Enthusiast's website. Very good step-by-step photos and tips for getting into the doors. This was for a door lighting project he did, but you'll find it very helpful for your project.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Mar 09 2014
    Thanks - awesome link but wondering if it would be possible to get a black door panel and then swap my (red) side inlay into it?
    Thanks
    Mar 09 2014
    bump.....
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I have a rattle or buzz in my drivers door. It is the under side of the arm rest portion. It is plastic under there and it occurs right where two parts come together. If I put pressure on it with my finger it stops. Not sure how to fix something like this. Any thoughts.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Established Member Two Rings ValidatedS4's Avatar
    Oct 08 2017
    2013 S4 6MT
    Boston, MA
    Door Panel Rattle
    Rattle From Rear Passenger Door
    http://www.audizine.com/forum/showthread.php?t=794935
    Check out this thread. I had to tighten the torx screws on my door.
    Worse case is take the door apart and add insulation/replace clips and snug everything back up. I don’t think replacing an entire panel is necessary yet..
    May 20 2010
    Go buy some dynamat or equivalent (I had raammat) or some closed cell foam to provide some additional insulating properties. May settle down the rattle by damping the vibrations.
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    When you take the door panel off, you will see that the wires and held in by white plastic clips that snap into the door. They aren't very snug. Get some dynamat and tape it over these areas. Also the wiring is a bit loose, get some tywraps while you are at it to secure everything nice and sng
    BMW M850i
    Mar 09 2014
    Dealership ended up only making the rattle worse
    Took off my door panel today and fixed the damn rattle myself!
    Use the shimmy tool to take the insert off, under here you'll find 2 T20 Torx Screws
    Take off the plast insert under the armrest, there will be 2 more T20 Torx Screws under here
    Don't forget this last screw under here
    Here is a nice pic showing all of the screw locations:
    You can see the loose wire the stealership left for me
    Dynamatted
    Also replaced a couple of broken clips on the door panel
    Rattle is 100% gone, road noise is decreased
    Aug 31 2017
    SouthEast USA
    Where did you get the shimmy tool from?
    Aug 31 2017
    SouthEast USA
    Nvr mind, found it:
    http://a.co/9SfcZXj
    Mar 10 2017
    Audi
    West Chester NY
    This is great. Thanks alot for posting this, im having the same exact problem on my rear drivers side door. Took it to the dealer and like you, it got worse. Such bs and its anmoying af. Will be doing this Tomorow to all doors :)
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Quote Originally Posted by tsitalon1 View Post
    I got my from harbor frights . 6.99
    Mar 10 2017
    Audi
    West Chester NY
    What is hard to pry out the trim on the door?
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Quote Originally Posted by 16s4vil View Post
    Make sure you start on the outside of the trim. The side closer to the outside door handle, not the side closer to the inner door handle. The clips on the inside are like a hinge. If you start there, you’ll break them.
    I just pulled the entire panel to replace a rear door lock actuator.
    I followed this:
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
