Page 1 of 3 123 LastLast
Results 1 to 40 of 104
    Established Member Two Rings Christo's Avatar
    Oct 23 2016
    South Africa
    Audi rs4 b7 2jz engine swap
    Morning all
    I know a lot of you will disagree, but I blew my engine on my rs4. I was thinking of doing a 2jz swap, and keep the awd?
    Sent from my SM-G920F using Audizine mobile app
    Veteran Member Four Rings MugelloB7RS4's Avatar
    Feb 06 2015
    While I'm a diehard V8 guy, I think this could be a cool project however I don't know if there's enough room in the engine bay. A straight 6 cylinder will be longer than the V8 that's in there and if you look now, there's not really much if any extra room to work with.
    If you're going to tackle a project, good luck. Keep us posted, but make sure you do lots of research before you sink too much money into this.
    Oct 23 2016
    South Africa
    The straight 6 is much longer than the v8, but its in
    Oct 23 2016
    South Africa
    Oct 23 2016
    South Africa
    This pic is with the 2jz in place and radiator fitted, still needs a few adjustments on the bumper but I'm not to worried about it for now
    Feb 06 2015
    Holy shit, you're that far along with the project? That's pretty awesome. If you can swap it in and keep the quattro system, that's pretty sweet. Keep the updates coming.
    Oct 02 2005
    The Moon
    Posts at 10pm last night he's thinking of engine swap. At 9am posts he's done...yeah troll much?
    Mar 11 2008
    B7RS4 & e46Ms
    FRRG AZ Ring
    Active Member Two Rings YoungDriver's Avatar
    Jul 24 2017
    Austin, TX
    I'll believe it when I see the engine in the engine bay
    Oct 23 2016
    South Africa
    Oct 23 2016
    South Africa
    Is still awd, I can send you all the pictures I've got, but I'm not finished yet
    Oct 23 2016
    South Africa
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    holy shit!
    whats the clearance of the IC and that passenger side front tire/wheel-well?
    f**k turning?
    2015 B8 SQ5
    Click Here
    Past
    Oct 23 2016
    South Africa
    The clearance is perfect, probably doesn't look like that from the angle
    Jul 24 2017
    Austin, TX
    Well I dont know how this timeline worked but we have been proven wrong..
    That is something!
    Cant wait to see the details on this build!
    Oct 23 2016
    South Africa
    I'm just not sure how I'm going to get the rev counter to work?
    Active Member One Ring ChapStar's Avatar
    Mar 14 2017
    USAFA, CO
    I'm extremely interested to see more details from this build!
    How long ago did you start on this?
    Sent from my LG-H932 using Audizine mobile app
    Jan 29 2010
    north ga
    fuck a core support, fuck a crash bar, who needs those things anyway?
    please proceed sir, you have our attentions and we'd all love to see any and all pictures as they come
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    lol this is great, I think you went a little past the thinking part.
    Oct 23 2016
    South Africa
    Hi I started September 2017
    Oct 23 2016
    South Africa
    To keep awd was the biggest challenge
    Account Terminated Four Rings
    Apr 30 2017
    holy mother of god MOAR !
    Aug 09 2012
    Bay Area
    % wise how far done are you?
    Veteran Member Four Rings elewsader's Avatar
    Mar 24 2006
    2003 A4 1.8T Avant MTQ, 2001 Audi S4 Sedan
    Central, IL
    subscribed..
    Ed
    why say lot word when few word do trick.
    Oct 23 2016
    South Africa
    About 90%, i still need to do exhaust, and ecu and tuning
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    This is great man, can't wait to see it at 100%.
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Oct 23 2016
    South Africa
    I'm also very curious
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Who made the adapter plate for engine to trans?? I’ve been looking to maybe try something different under the hood and keep it AWD. Wonder if these plates have come down in price from my last searches.
    Oct 23 2016
    South Africa
    I couldn't make a adaptor plate because of the length of the engine it was past the grill so I cut the bellhousing, and gained 60mm, I hade no other choice
    Oct 23 2016
    South Africa
    Jan 29 2010
    north ga
    you guys don't fuck around in South Africa
    Oct 02 2005
    The Moon
    Damn, get drunk the night of the idea being conceived and work through the night. WTF!?
    Oct 23 2016
    South Africa
    I take it as a compliment, thank you sir
    Senior Member Three Rings georgio3gr's Avatar
    Jul 14 2009
    Greece
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by BCsniper View Post
    this
    Sent from Sony mobile
    | Autospeed | JHM | Pure MS
    Feb 10 2012
    parts
    Napanee, ON
    Quote Originally Posted by Christo View Post
    Wonderful! And you welded the 2jz housing to the Audi trans? Is it cast aluminum or steel? I have never thought of this. 60 mm would be huge. I think I was 40 mm into the rad w plate, losing 30 mm for plate and then 60 mm would make huge amount of space. Could perhaps retain AC much easier plus engine back a bit further I think it might make overall balance different.
    If you have any specs on how you adapted the trans flange I’m certainly interested in how you did this.
    Oct 23 2016
    South Africa
    I bought a dubbel plate aftermarket clutch and had a custom flywheel made. I measured them together and allow for the fork and release bearing, I then got a 2jz block and machined the stock 2jz bellhousing that I just had the ring. I machined the remaining of the Rs4 transmission, then lined them up using the main shaft. That is in short.
    Oct 23 2016
    South Africa
    Hi guys just a progress update
